Wire issue?
97 gst turbooo
132
Aug 26, 2006
Lowell, Massachusetts
ok recently this just happened after garaging the car for the winter. the fan motor inside the car dosent work neither does the rear defroster. all fuses are good. if i turn the headlights on and try either of the two it turns my horn on? i dont know where to begin. any help?
Sounds like you might have had some unwanted tenants in there.
When you hit the defrost button, does it light up? If it does, check the 2 wires on the rear glass and ensure they are not simply off.
Pull the fan control section out of the centre console and check for power and ground there too.
If no power and fuses are good as you stated, start tracing wires....from the centre console towards the fuse panel...don't be surprised if you find a little nest thingy in there!
That's where I'd start...lemme know if you need anything else like diagrams, or anything else.
