JamiesTSI
- 263
- 6
- Sep 6, 2004
Johnstown,
Pennsylvania
Well the motor is just about tore down. Some things I noticed are:
1. Mains not tied together. E-mail sent to Kiggly racing about there mains girddle kit.
2. Should be able to use an aftermarket 6 bolt oil pan if I want to. The G4CP block I built, I had to use 97-98 Hyundai Sonata oil pump/oil pan ONLY.
3. Front case will need to be changed to a 6 bolt.
4. All timing items from a 6 bolt will have to be used.
The bore on the cylinders look good. I can even see some old cross hatching.
