Windows... : /
Bubba9110
70
Apr 13, 2010
Madras, Oregon
Ok so I have my 95 TSi AWD and I need to know how I can tighten the windows. Every time I shut the door you can hear the glass hitting the sides of the door so it's not like tight inside and then also water can get in through the windows at the cracks. Can you guys help me solve this problem? Also if anyone knows a good product to use that can take off condensation spots from the windows that'd be great if you could let me know. The windows are foggyish on it and I'd like to clean them up as best as I can. Thanks again! :)
i have the same issue with the glass. im gonna guess that's just how it's made?.....
Ok thanks for the diagram. Oh by the way did you mean use a clay bar? And if so where can you get one of those and what's another name for them if there is one. I'm unfamiliar with them. Thanks again.
look in the tech section there is a write up on this, i believe its called the window rattle fix. Its very common on the 2g's
Adam's Clay Bar & Detail Spray Combo
Just google "Clay Bar" and you will get hits. My uncle loves just a clay bar for the glass but I've heard of people needing a polish as well.
Figured I'd just revive a newer thread rather then make a new one. I fixed the loose plastic piece on the front rail, but my driver's window still rattles at the back rail. Every screw is tight so I dont know where to go from here.
Yeah ibhave same problem. If anyone knows a good site can you please send me link to get new rail. Appreciate it
Yeah I have problem but my rail is like bad. If anyone knows a site to buy from please and thanks. Appreciate it. I tried alot as well
I'm having the same problem also. My car inside is foggy as heck and looked like it just rain in there. I'll check out the links and go from there. Another cheap dsm effect.
  • Wanted 6 bolt NT water pipe
    • chrisman287
