Window fuse
Bubba9110
70
Apr 13, 2010
Madras, Oregon
Ok so I have my talon and last night i was driving around and then as my passenger was rolling the window up it stopped working so i assumed the fuse blew. So today i checked and sure enough it was so i replaced it and everything was fine. Then tonight the same thing happened. It rolled up slow then stopped working. So i checked the fuse and it was blown again. Can someone give some insight on as to what's wrong with my fuses? Thanks.
*EDIT*
Ok, 18 wires soldered later and I have my fuse problem fixed :thumb:
Hi. It sounds like you have a short somewhere. More than likely, you're power window switch has gone bad causing a short. Less likely, although not uncommon, is a break in the wiring somewhere causing a positive wire to ground itself.
