2G Wilwood brake and 15"rims
dude1988
141
15
Sep 12, 2010
orange, Connecticut
Ok so I looked on a million posts about people running wilwood brakes and a 15 inch rim. I see a lot of rota slipstreams on them. How do you make them fit!? I just bought a set and there a no go. Any suggestions or other rim to use? The slipstream I just tried was a 15x7 35mm but would need like a inch spacer to make it clear the caliper (and that's not happening)
Old thread but I’m looking for the same info. Looking to get 15” wheels for slicks but want to make sure they fit my wilwood brake s before I buy them.
Was looking at slipstreams but if I knew a different 15” wheel would fit I’d go that route.
You'll need to make some changes to the Wilwood kit. You'll need to swap out the rotors to 11.75" rotors. And then machine spacers to bring the caliper back down ~.220". Even after this, it's still hit or miss if a 15" wheel will fit. Fitment all depends on the size and shape of the barrel.
I can attest that if these mods are done, 15" Motegi Trak-lites will fit:
