Willl 580cc Injectors maximize EVO3 Turbo?
Mr.Tao
265
Jul 11, 2003
Atlanta, Georgia
550, 580, 660?
I'm leaning towards the 580's and hope that it will push the Evo3 turbo to 21 psi. Any suggestions?
alright...sounds good. The reason why 580's because Extreme Psi has them for $280 or $290. The 660 are around $309.
Originally posted by 98RedGs
I'd pay the extra 20 bucks for added security.
The EVOIII doesn't flow a whole lot more than the big16g. 580's will be fine and easier to tune.
Originally posted by L2RTSiAWD
Why is your base pressure 50psi??
Couple of reason's, first I have a walbro 255 which overruns the stock fpr, so I got a B&M comand flo and turned the base pressure up to where I was overrunning to. This makes tunning much easier because my fuel pressure is linear. Second if I didn't have the fuel pressure that high I'd have to set my emanage for around 640cc injectors (the PTE injectors I have flow much less than advertiesed, there was a thread around some where I saw where a guy sent some to RC to get flow tested and this was the average flow), which would bring my duty cycle up much higher than I'm comfortable with.
The Hahn 625s are rated at higher FP and maybe even higher duty cycle as well. Most reports I've seen say that they flow more like 550s. The 580s, if they're PTE injectors, will also probably flow more like 550s because they're supposedly rated at 90-100% duty cycle, I'm told. I just picked up a set of PTE 780s, which should flow about like 750s.
