Will EVO cams work in a 2g or 1g head?
snox135
678
5
Jun 6, 2002
Southern, Wisconsin
I have a buddy who has some performance cams for an older EVO. I'm not sure which year EVO yet. I do know 1,2, and 3 Evo cams are different from 4,5,6 and 7. I'm in the process of building a 2.4 right now and i wanted to get these cams. But I'm not sure if they will fit.
The cams specs are as followed....
Intake duration @ 1mm 224deg., duration 272, 12.00mm valve lift, timing 28 open 64 close, 108 deg. full lift
Exhaust duration @ 1mm 224deg., duration 272, 12.00mm valve lift, timing 63 open 29 close, 107deg. full lift
If anybody has info on if these will fit please let me know.
Evo 1,2 and 3 should work just fine. After that, they switched the cam gears to the other side.
