Will AWD RMDSM Sway bars bolt on a 2GNT
You can always call up MachV since they sell them. If you do, I don't see why you wouldn't be able to replace them with the RMDSM bars. If you don't have a rear bar, then you'll have to get some extra pieces so that it can attach. Here's a link for reference, but I'd give them a call and see what they say.
And as far as I've read, this bar is the only one that can work with a 3" exhaust. I have them on my car and love them!
Also, this is one of the only places that I've found that sells these bars.
http://www.machv.com/rmracswaybar1.html
Are you running the AWD bars of the FWD bars??
Thanks
I have a GST so I have the FWD bars. If you want any pics, I have some of the pieces after I took them out of the box and then a few of them installed (of what I could take with the car on the ground).
Although, I've read there isn't any difference in the AWD and FWD bars. Not 100% sure on that, but again, that's just from what I've read.
Yes, please post some pics or I can PM you my email address.
Thanks
Here are a few pics. If you'd like more, let me know and I'll snap whatever you'd like.
Kit - includes bars, prothane bushings, lube, and instructions
Rear Bar installed
Rear Bar connected to endlink near suspension
One major word of advice. If you plan on doing this, get new sway bar end links (where the ends of the sway bars will bolt to). You probably won't be able to get your current ones off and will have to cut them off...although you may get lucky and be able to just unbolt them. But I had a heck of a time with mine (took me 3 or so days to get them all off) but got new ones all around which helps a lot. Hope some of these pics help! Again, if you need more, post or PM.
:dsm:
