will a loose front sway bar end link cause:?
myblack98gst
578
Jun 22, 2003
Elizabethtown, Kentucky
while putting my springs on the end link bolt (on the passenger side) stripped out and I cannot get it to go on tight...
at the same time I also welded the differential solid. but these are the only 2 things I changed..
while driving in 5th if I mash the gas the car kind of feels like it pulls to the right, not really a torque steer type pull but more like the car just heads that way??
and clue?
only thing I could figure is the loose link allows the left side to lift more and the steering to pull the car right?
I doubt that it's the sway-bar or anything related to it since (a) these don't do a whole lot when you're going straight (or straightish, in your case) and (b) when a link breaks, the bar ceases to have an effect on either side (assuming the mounts aren't jammed).
More likely... With a welded diff, you must make sure that your tires are extremely-well matched in diameter. Even a difference in tire pressure will cause the car to drift to one side.
- Jtoby
With my end link broken. I can feel the alignment off. My cars alignment has always been good and before it broke it was fine... SO now that I see its broken I can feel in on that side. Also when I cut my wheel hard in reverse I feel a dragging feeling as the bar and link move around and hit things
