Will 99+ gallant strut assemblies fit a 2g
1999 Galants have a McStrut setup. You have a Multi-Link setup. Research more.
The 94-98 Galant in North America, and also the 8g Galant in Japan. Maybe that is the Galant you are thinking of when you say 99+?
You aren't likely to find a gravel or rally suspension for a 2g largely because a 2g doesn't have the front suspension travel you'd want in a rally car. There is a reason they used a McStrut in all the Evos. It isn't quite as good as the multilink front on tarmac but it can handle big bumps and jumps better.
Depending on your level of commitment to your current platform you may be able to do a McStrut setup in your 2g with a lot of work and research. Really though if you want to rally a DSM go get a 1g.
