wierd cutch sounds
FRslimmyjim
144
Dec 28, 2010
warwick, New York
hi,
i just built my 420a and turbocharged it and everything :hellyeah:. i put a south bend clutch in it and it is making a noise when i press down on the clutch but it only starts to make the noise when it is fully pressed in :banghead:. is this normal since it is a high performance clutch and it came with a throw out bearing and i installed that too. this is my first build since im only 18 so i dont know how it is supposed to sound :hmm:. any help is appreciated. thanks
You installed it yourself? Check the throwout bearing, pressure plate, bushings, and cluth pedal assembly. Describe the sound and does it occur only when the clutch is engaged?
The sound is like a spinning sound almost. it is extremely hard to explain. it only happens when i push the clutch pedal all the way down. I didn't adjust the clutch pedal could that be it? how do i adjust the clutch pedal?? i have the haynes mauuel, would that tell me how to do it? it doesn't make the noise when the clutch is about to engage or is slipping.
So it's a constant whirring grinding noise while the clutch is in? and it doesn't stop until you let go of the clutch. Does your clutch feel stiff or spongy? Theres a couple bolts at your clutch pedal, google clutch pedal assembly and adjustment. Could be that, it also sounds like it might be a throw out bearing if it only sounds when the clutch is in. try bleeding the clutch and topping it off.
A clutch pedal that's not adjusted correctly could cause the symptoms you're describing. I had a similar issue where I heard spinning/scraping with the pedal pushed all the way to the floor, and only then. I then adjusted the clutch pedal according to this video:
Clutch adjustment
and the noise disappeared. Give that a shot, since it isn't very difficult and may solve your problem.
  • Wanted 2g Test Pipe/Straight Pipe
    Just wondering if anyone has a test pipe that replaces the stock cat for sale. No preference for...
    • DankYeezy
  • Wanted 4G63 Ecu 1g 1991-1994 Eprom socketed
    Wtb Ecu 1g 1991-1994 Eprom socketed in good working condition!
    • niki_talon
  • For sale 4G63 Stainless T3 header w/38mm wastegate flange
    Same header you can get for $230 on eBay. Like new, only ran for 10min or so. Price is shipped...
    • GRNDSM
    • dsmmario
