Why is my car stalling???
mitsuclipsegsx
2,561
8
Apr 5, 2004
Dover plains, New York
i had this place put on a 1g tb on my 98 gsx auto and when i got it back it was reving really high 2800 so i decided to just put the stock one back on and i found out they didnt even port it,LOL so anyways i put the stock one back on and ever since its been stalling as soon a start the car, but once i drive it and it warms up its fine, and somtimes it will rev high,like 2300, is it the ISC sensor what should i do, is it ok to spray carb cleaner in it, whats werid is my stock one never gave me probelms till they put the 1g tb on and i put the 2g back on :confused:
A bad intake leak would do that. Did you use any sealent on the gaskets?
Do a pressure test. I like the spray on copper coat. It is good for extremly high temps and there is not a lot of excess that will get in places it's not supposed to.
Yeah if you are using a new gasket you don't really need to use a sealer. I do anyway just to be safe. But when you are reusing gaskets they loose their ability to conform to the sealing surface so you need something to make up for it.
I had the same issue before, It turned out that the throttle cable wasnt on there right.
  • For sale 2g 2G Ignition Cylinder, Key, All Locks
    2G Ignition Cylinder, Key, All Locks $115 + shipping & paypal feesYou must be registered to...
  • For sale 4G63 Buschur Racing Dual Stage Boost Controller
    Buschur Racing Dual Stage Boost Controller $95 + shipping & paypal feesYou must be registered...
  • For sale 1g Griffin Intercooler cores.
    Griffin intercooler cores. Top to bottom flow of course. Very low pressure drop and high cfm...
  • Wanted 2g 2gb Talon / Eclipse -
    Looking for 2gb talon/eclipse. Willing to look at anything.Does not need to be stock, prefer...
    • KCDsmDude
  • For sale 4G63 JE 85.5 mm pistons for a 2.3 L.
    JE part #986E pistons. 85.5mm Quantity of three. 9.5-1 22mm pin. For a 2.3 liter. Good...
