which air/fuel controller?
Dan97gst
70
Sep 5, 2006
Hixson, Tennessee
I am looking into getting an air/fuel controller, and the two that i am looking at right now is the greddy emanage(piggy-back) or the S-AFC. Out of these which do yo feel is better as far as user friendly goes. Also if you have any other suggestions of a different type of a/f controller let me know. Thanks
Not Sure Ive never used the EManage system. I have used a S-AFC, DSMLink and AEM EMS. I between the two that you want I would say the S-AFC but thats only because ived used it before. The EManage might be better I dont know.
If your going for a piggyback system and you have a eprom ecu and can spring for it I would say DSMLink. That would be my choice.
The S-AFC II is really quite simple to use. But if you are looking for something that you will be able to use to check basically everything than go with the DSMlink.
The SAFC is easy to use, but the emanage will give you a lot more options, IMO. Allows timing control, logging, and using something other that TPS if desired. You'll need either a laptop or an e01 to properly use the emanage tho.
