which 16g install kit needed for 2g with FMIC?
fastfive0
418
3
Sep 22, 2002
Pocono's, Pennsylvania
Just wondering as the topic says, ive searched and nothing mentions a FMIC. So do all I need is the oil lines and gaskets or should I buy the install kit. Its an Ebay evo 16g
Is it a short route FMIC setup? & this is for a 2g? You don't really need an install kit, just need a SS oil feed line, can reuse your stock drain tube with a simple modification. Can reuse your stock coolent lines with abit of bending, just need to replace the 4 14mm crush washers. Other then that, gakets & if it is a short route FMIC you will want a jpipe that comes down between the compressor cover & turbine housing (on the drivers side of the front motor torque mount). Dejontool's jpipe is the style your looking for (other vendors will have this style as well).
yea its a short route kit. So i should just get the 4 14mm washers and the j pipe from dejon and everything else will be good? Someone was telling me that the bolts for the turbo are different on the ebay evo16g then a regular 16g is this correct? Your help is greatly appreciated!
Add a SS braided feedline as well, but yes other then any gaskets you think need replacing, you should be good. As far as the bolts being different, I have no idea, but wouldn't surprise me with being a knock off.
ok so i just checkout of dejonpowerhouse's website and they sell a j pipe and a u pipe....it says the u pipe is for the t25 and the j pipe is for the 16g. So i would need the j-pipe right?
Still didn't order it yet?.....What you waiting for christmas.....Get your crap together then maybe you could hang with the galant ROFL looks like it'll be another 2 weeks before the next long weekend (weather permitting)
