where to get new/rebuilt turbo
4ged4G63
421
4
Sep 6, 2002
Arizona
anyone know where I can get a rebuilt 14b turbo from?
not sure I want a 16g upgrade, I like the 14b but mine is old so I want a new one.
whos got nice rebuilt ones for sale?
Just out of couriousity, why pay $300-400 for a rebuilt 14b when you can get a new e316g for a couple hundred more???
Just a thought...
the evo16 is a good turbo, it can go up to 400 hp with supporting mods ofcourse, but if you want the 14g it's ok go ahead and rebuild the 14g =) sounds good :thumb:
A typical turbo rebuild is $345.00, and involves the following steps:
Complete disassembly and inspection - turbos we receive are identified, marked, and torn down to component level. Each part is inspected for wear and/or damage, and cause of failure is identified.
Cleaning and sandblasting - Turbine and compressor housings, bearing housing, and turbine wheel are sandblasted and refinished. If your housings are specially coated, we clean them with solvents to avoid damage to the coating. The bearing housing is flushed with solvent and honed, and the turbine shaft is polished to a mirror finish.
Blueprinting - Journal bearing bores are measured for oil clearance. All reusable items are checked against specification.
Reassembly - Turbo is reassembled with new journal and thrust bearings, o-rings, piston rings, fasteners, thrust collars, and seal plates.
Balancing - Turbos are dynamically spin balanced as a complete assembly to less than half the manufacturers allowable limit.
http://www.forcedperformance.net/services.aspx
happy now? :thumb:
  • Wanted 6 bolt NT water pipe
    • chrisman287
