Where do you guys get your fuel line kits?
elementalwindx
745
5
Aug 13, 2003
Wilmington, North Carolina
I need to either a) piece together, or b) buy a premade kit that is -8an feed, and -6an return with an aftermarket filter and the an fittings for the fuel rail. I need it to go from an in-tank walbro 255hp, to the rail and back to the tank. I need to get this done asap for the talon I'm putting the motor in. This is on a 95 awd talon.
Anyone know where I can get this done asap? I'm looking around as I type this.
Well, for a -8 feed you will need some custom welding done to the fuel pump housing. Look at my pictures and you could see what I did. Use www.stevetek.com to help you out with basic guidelines and it would be alot cheaper for you to do it yourself than for someone else to. But, if you don't have the confidence to do it then go ahead and ask someone else to. Alot of stuff I got was from summit racing but, it is up to you. 11secgsx did an awsome job on his. If you want some help with this PM me and I will try to walk you through this.
