Where can I get a crank nitrided?
dsatchell
62
Dec 14, 2010
Austin, Texas
I've got a forged 4g64 crank that I want to get nitrided but can't find anyone that does it that is reputable.
So does anyone have recommendations on where I can get a crank nitrided and how much it runs?
Thankx.
They just bake mitrogen into the aluminum to make it cleaner and much stronger. Think of putting a titanium coating on a wooden baseball bat. It also holds lube better.
Thanks for the clarification. Yeah I knew why they did it just was unsure of the process ie. baking, dipping, or what not. Either way I would say a $300 price tag is quite large for that
What crank is aluminum?
Not aluminum. let me correct myself. Whatever steel they forge it from in DSMs. I don't think it's the carbon steel and i know it's not the cheap iron cranks they make now. and it's not baking like you would a set of rims. They have to put it in a vaccum and blast nitrogen into the surface. it doesn't help deep into the steel, it just coats it about .25 MM into the surface.
