When and where to use RTV, Locktite etc etc
bigemrich
519
Jun 1, 2004
Butler, Wisconsin
I currently have my DSM all tore up, which essentially means head off, timing belt side all disassembled etc etc. What I am wondering specifially is what kind of sealants or fluids (ie RTV, Locktite) do I need and where do I need to use it. In other words which bolts/gaskets need extra care and what care/extra do they need? Any tips or small things that would help in the nit picky area would be appreciated, I dont need the main reassembly or anything, I think I have that, just small things that one may forget or not know... Thanks a bunch, it is appreciated :thumb:
--Kyle :talon:
Anyone? Im gonna be reassembling real soon and I want to make sure all my gaskets and such seal but I dont know what type of sealants to use or where...Can anyone give me a quick list, it would be really appreciated.
--Kyle :talon:
I'd say anything prone to coming loose due to vibrations, or things that you REALLY dont want to come apart, thats where you want the Locktite(R). I'd use them on the cam bearing caps, that nut on the oil pump sproket, delivery body, oil pump gear housing bolts, alternator bolts, all pulleys, just anything you dont want coming loose. I have no balance shafts and Prothane motor mounts too, so you see why. Oh, and if you have the stock water-->>oil cooler, use some on that too, some people say it backs off, but it hasnt happened to me. Just use your better judgement, you'll be fine. I'd use the red high strength stuff. As far as sealant, use it on your oil pan flange, pressure fittings, or any kind of fitting thats going to be pressurized or whatever. You can buy your own gasket material from Advance Auto so theres never the need to buy new gaskets for throttle body, turbo outlet, or whatever you need to make gaskets from when you tear them.
--Kyle :talon:
You're gonna be on your own real soon if you bump a thread again.
  • For sale 2g 2G AWD Fuel Level Wiring Harness
    2G AWD Fuel Level Wiring Harness $35 + shipping and paypal fees* removed from 97 TSI AWD * all...
  • For sale 2g 2G OEM Passenger Door Handle
    2G OEM Passenger Door Handle $25 + shipping and paypal fees* the seal and two mounting bolts...
  • For sale 2g 2G OEM Interior Silencer Pads
    2G OEM Silencer Pads $20 + shipping and paypal fees* these go behind the plastics to the left...
  • For sale 1g 90 Oil Cooler
    90 OEM oil cooler with custom lines. Takes 18x1.50 mm fittings at the housing. Fits in a...
  • Wanted 2g 2G FWD Fuel Filler Rubber Hose
    Decent condition FWD fuel filler hose.
    • kyler021
