Wheels and drop
Plick21
Feb 19, 2004
Huntersville, North Carolina
ok i am thinking of getting adr sterlings for my 2g. they are 18/8.5 with 225/40/18 tire. will these fit with a drop? i have ground control coilovers and kyb agx shocks. just looking for some help. thanks.
ps getting a camber kit soon also.
225's should fit fine with any offset up to about 50. You'll likely find them in the 38 to 40mm range which is fine, even with 235's.
vfaq.com has a pretty good explanation.
http://vfaq.com/index-main.html
Offset describes the plane your wheel's tire mounting area is centered on in relation to the hub mounting surface. At least a basic understanding of offset is critical when selecting your own wheels.
