Wheel stud frozen
falcon8r
205
Sep 15, 2009
kalispell, Montana
Hi all, I have a rear lug nut that is frozen onto the stud. The stud just spins in the hub. It did unscrew enought to be loose somewhat. I fit a 3" cutoff wheel into the stock 16" turbo wheel but the abrasive is too small to reach the stud and a 4 1/2" wheel is too big. I also tried to weight the car on that stud and loosen it or break it. I used direct air off my compressor @ 175+ psi too with my impact gun. Help.. any good ideas before I booger up the drive hub on the 4bolt axle ? I have a 3 leg Talon :| Thanks, Tres....
