2G Wheel offset
ssjrrupp
Jul 15, 2012
West Bend, Wisconsin
Hello,
Currently building a 95 GSX for road racing and need to buy wheels in order to continue the build.
Car will be track only, regulation 4" ride height (as measured from the highest point of the rockers not including pinch welds or mouldings), custom JRZ RS-Pro coilovers(which should be in the catalog after my build) and 245/40 or 245/45 Hoosier R6's, stock knee assy, stock ctrl arm spec assy, probably camber adj ball joints (not sure)...
Just wondering given the ride height and tire size, in a 17x8 wheel, what offset should I be looking at.
Been leaning towards the Enkei RPF1 for weight and durability. I don't like the looks of them much, though. Like the looks of the OZ Ultraleggara but at 17.5 lbs + vs 15.6 for Enkeis it's kind of a no-brainer as this isn't a fan-boy car.
All comments, conciderations and recommendations are appreciated.
Thanks,
Justin
K-is knuckle clearance
f- is fender clearance
this is for 2g ,believe stock height but you get the idea.
