Whats this oil peice called?
KooK
188
Dec 7, 2002
Ames, Iowa
I'm trying to figure out what this peice is called so I can order a new gasket for it.
Its the thing that you put your oil filter on, it has one stock sensor on it and you can add another oil pressure sensor on it if you want. Its on the bottem drivers side of the engine, on the side of it. Has 5 bolts that goes into it and you need to lift the timing belt cover just a little to get to it. By the way, it also has antifreeze, as well as oil running through it. Whats that chunk of aluminum called?
Thanks!
