Whats right next to the kock sensor pigtail?
rpg_dog
44
Sep 20, 2008
Colorado Spring, Colorado
I have 2 pigtails coming out of the harness, one that will fit both the knock sensor AND the connector on the intake manifold brace (both look about the same), and the other doesnt fit either due to there being no groove for a nub to travel through. I'm tempted to cut the nub off of the connector on the intake manifold brace to allow them to connect, but I don't recall this being an issue before. Where the hell does this pigtail plug into?
The knock sensor is a gray plug. B-07: Knock Sensor
There is a EGR temperature sensor plug back there, just to the driver's side of the knock sensor connector. It is used only on California emission vehicles so you may not have the sensor at all. B-08: EGR Temperature Sensor
It's not for the cruise control because the cruise control has a 4 wire plug, not two like each of these.
Thanks guys that would be the one, I'll just tie it back then. So is there anything that plugs into the connector that was on the intake manifold bracket?
Pics of said connector on intake manifold bracket? It might be for the EGR temp sensor -- do you know if your car is a Cali emissions vehicle or not?
Turns out it was just the missing pigtail end probly from an old knock sensor that was ripped off. At least it looks the same as the end on my new knock sensor. I thought maybe it was a ground for something. Thanks guys.
  • Wanted 6 bolt NT water pipe
    • chrisman287
