what year is my engine?
shmoo
Jan 9, 2010
blairstown, New Jersey
so i have a 98 eclipse with a turbo engine, the only problem is i need to pinpoint the year so i can figure out what parts i can actually put in. i checked the vin on my tranny but cant locate the one on the block. as far as i know the tranny is a 95 from lookin up the vin. but the vin on all the panels and on the fire wall tell me its an rs. is it possible for a 95 tranny to match up with different year engines or is my engine most likely a 95 4g63T? oh and i also know its a 7 bolt because i just had the tranny rebuilt so 90-92 is definitely out.
If the car is a '98 GST like your profile says, then you can count out the fact of it having an RS trans in it. The RS models use a 420A motor/trans from the Dodge Neon.
the title says that its a 98 rs, but since its turbo i know there has been a swap done im just trying to figure out the year of the engine itself, and i'll post pics tomorrow. i would now but its a little dark out LOL.
If it has a cam and crank sensor then its a 95-96 if it has CAS looking thing like the 1g on the intake cam then its 97-99. If you open the driver door and look on the side it has the manufacture date, remember if it says 96 the its 97, if 97 then 98 and so forth.
