What to use to seal up the tube off the turbo outlet?
vtracer20
407
Oct 1, 2004
Milton, Vermont
What do i used to seal up or w/e the little tube coming off the turbo outlet pipe...i need to take off the tube and seal it up? thanks
wont that melt...cause arnt they rubber and my guess is that the outlet tube gets very hot....if not then this should fix my problem
i dont think its goin to melt unless u run excessive boost and REALLY heat up the air. Try it and see what happens.
piece of vacuum hose with a screw in the end of it :D, worked fine for me for a year or two.
I used a Silicon vacuum cap and one of the factory pinch clamps. Still holding after over 2 years. :D
