what t-case is this from
magik95
401
Feb 24, 2008
aurora, Colorado
So I locked up my t-case and just got another one last night. Its suppose to be from a 1g. I go and try to put it in and the damn thing doesnt fit!:mad:
Like a dumb ass I didnt ask if it was from a automatic:toobad:. So my question is does anyone know from a pic what t-case this is from? The one on top is the new one.
I just went out and slid the driveshaft on to the t case and it went right on. But it wont go on the tranny out put shaft. I counted the splines and they are both 23. If the drive shaft fit shoudlnt it fit the tranny since its a 23?
I have a 6bolt swap in my 95. The motor and trans are form a 91.
they are also different from auto to manual due to gear ratios, dont know if the 1g manual is the same as a 2g manual ratio though.
you should count the splines again just to be sure. the transfer cases from the 90-91s were 22 spline and the 92 after were 23 spline. chances are that the case you got is a 22 spline. oh and im pretty sure that all of the driveshaft splines are they same.
your most likely going to have to change the output shaft in the tranny. its pretty easy. i can walk you through it if you want.
1g's are the same, except for the linkage in 90.
The difference might be the 7 bolt bellhousing, I know the trans/engine plate spacer the starter is slightly off, but they were both 7 bolts, early and late.
Just checked mine, 1g is cast iron where the input shaft is.
I tore apart the old t case and figured out I can swap out the drive bezel gear assembly to solve the spline problem. Process took about 15 minutes.:thumb:
Heres the carnage from my blown t case. Bearings gone bad!:beatentodeath:
  • Wanted 6 bolt NT water pipe
    • chrisman287
