What spline is a 90 tsi most likely??
swing lo
556
Jul 23, 2003
Jacksonville, Florida
I have a 90 tsi awd and i need a new t-case. What spline is my t-case most likely to be cause i have not took it off yet to look. I think it's a 22 spline.
And do most 90 awd cars have a 22 spline?
Yes you have a 22 splines, only 92+ have the 23 splines, the only disadvantage of the tranny with the 22 splines x-case is if you plan to upgrade your center diff (4 spyder or Qauife/Kaaz...) you will need a 23 splines and a tranny from 92+...
thats interesting, the 3000gts/stealths have 18 spline for 91-92, and 25 for 92.5-99, and i always thought these awd systems were the same, maybe they arent.....(i know the tcase is, or at least the yoke that leaks is....)
  • Wanted 6 bolt NT water pipe
    • chrisman287
