What psi to run after rebuild?
SnowBird
527
Jul 9, 2006
Cleveland, Ohio/Tampa, Florida
Still on the 14B, new stock pistons 20 over and all new crank/rod bearings. Do I just run the stock 10psi?
Do a search I just saw something on breaking in...
Here's what I do...
half boost. so 10psi. should be fine
use non-synthetic oil let it idle up to operating temp. Shut it off drain the NON-Synthetic oil
NON-synthetic again drive keeping it under 4 grand for the first 100 miles...Drain oil
NON synthetic again driving more normal now taking it to redline just not beating it!!!!
At 500 Miles drain and put in NON-synthetic for the last time and drive it normal...
At 1,000 go with you choice of oil turn up the boost and tune....
Like I said that's what I do.
