What Motor Does This Have
Status
Not open for further replies.
NoLmitSoldier44
May 24, 2005
Socal, California
k guys i was shopping for parts, im getting a 1991 eclipse and the owner says its a 2.0 liter non turbo, wat engine code is that i know theres a couple
-4g63
-a420 or soemthing
which is it?
thanks in advance
there was no 420a in the earlier eclipses. so that would be the 4g63 n/t. still capable to achieve a 4g63 turbo status.
edit: by status i mean that all the engines are able to be swapped/transplanted into each other and establish the factor of 4g63t. internaly they have there differences as also in structural limits. but neerly the same in aspect.
Well the casting in the 4g63T block allowed for oil squirters in the oil galley to spray the bottom of the pistons, but in essence you are correct.
k yea im planning on turboing it once i get it, has anyone seen these engines put out a good 14-17 psi, can it handle it?
I'm assuming you are replacing the internals to 4g63T spec, and if this is so, you will be able to run with the other turbo 4g63 guys are doing. Your boost limit is all in the tuning.
do you guys know of any good sites for parts for my car....
manifolds
turbos
pistons or anything
im using prostreetonline but i dont know if theres anything better
dsmtrader.com do a little search and ull find like 15 more, i like this the best
manifolds
turbos
pistons or anything
For parts like pistons/rods/bearings/etc I would rather go to a secure and reputable shop such as...
www.slowboyracing.com
www.buschurracing.com
www.extremepsi.com
but for simple bolt on items, I find eBay and the classifieds section to be quite helpful.
-4g63
-a420 or soemthing
which is it?
thanks in advance
In the future, use proper grammar.
Closed.
Status
  • Wanted 6 bolt NT water pipe
    • chrisman287
