What is that part? where can i get it?
twinkiemobile
107
Jul 21, 2004
Tolleson, Arizona
Hey everyone,
working on my car today, my father accidentally hit the radiator like thing in front of the actual radiator. He tells me it's connected to the a/c system, and that i need to replace it asap before the freon dries up or whatever.
Anyway, i was wondering what is the popular or technical name for this piece. so that i can search for it online and in junkyards, and maybe someone will know what i'm talking about.
- Also, does anyone know where i can find 1997+ front bumper, preferrably white? from a vendor or another person. I need to replace my bumper since it's cracked
thanks for any help
- Jose
It's called an a/c condensor. You can't fix it without the proper equipment to evacuate and recharge the a/c system.
Did it make a hissing sound when he hit it? Your freon or r 12 or whatever is in there and under pressure, if you punctured it it would leak out. If you didn't hear a hissing sound get your AC system tested, if it's still holding good it's probably ok.
bullshit
edit- you need a recharge set thats all
take a socket and loosen one of the lines to the ac system...let it pure, remove radiator in one piece....and remove condenser....it literally takes 30 minutes to purge, remove, install and charge
my father drilled a hole while installing hood pins into the condensor
97GS-TSpyder said:
bullshit
A recharge set? I hope you're not talking about those piece of shit cans you can buy at walmart...
boostvr4 said:
r12 is expensive too, like $45 a pound.
Yes, R12 is very expensive. That's because they don't make it anymore, as it's one of those things that eats away at the ozone layer. And don't put that other shit in it. I can't think of the name right now for some reason, but it's the stuff besides R12 and R134a. It contains propane and methane, making it highly highly explosive.
Yes it did make a hissing sound.. so i guess the freon or R12 leaked.. so this also means the condensor is ruptured.. is there anyway to have that fixed? or do i have to replace it then have the whole A/C system recharged? let me know..
- Jose
- Jose
Yes, replace it then have it retrofitted with R134a.
do you know if i need any other special equipment to have it retrofitted witht he R134a? How much do you think it will run?
Where ever you have it done may include the retrofit kit with the price for the recharge, but you can buy one from Napa or some other parts store.
