AEM What is needed for AEM EMS setup?
bignbumpin
91
Nov 29, 2003
Manchester, New Jersey
Im looking into different options for tuning my car when shes ready to go. AEM EMS seems to be the way to go in terms of the most control. I want to know what exactly im gonna need to setup the system for Speed Density. What kind of laptops are you guys using? What sensors do I need? Where can I get. Searches turn up vauge answers. Looking for everything. Thanks in advance... :talon:
Make sure you know what you are getting into with the EMS. It will do just about anything you ask it to, but can really be a pain in the a** at times to.
1. Go to the AEM forums page and read.
2. I use a IBM think pad.
3. GM AIT probe, GM 3 bar, and GM boost solinoid. Get the pig tails also. Part numbers can be found on AEMs web sight.
4. Go to the AEM forums page and read.
Good luck.
Mirage2LTurbo said:
You'll need a prayer to get your fuel pumps to turn on (and off).
Nah, don't listen to him :p I had a fuel pump problem, but the real problem was an engine harness had come loose. The EMS is the shiznit :cool:
I use all stock sensors except an AEM 5-bar MAP sensor, GM IAT sensor, and an AEM UEGO wideband O2 sensor/controller.
