What happened during this log?
90 GSX
322
Jun 24, 2004
Fremont, California
I have been chasing a gremlin with my car for months. The car hesitates a bit, it's down on power, it doesn't spool on the low end and it creeps on the high end when it never did before, the fuel trims are never consistent, and every once in a while the car starts to sputter like it just cut fuel to a cylinder or two. I do sincerely believe that the rare sputtering problem is the root of the problem and the key to solving it. I'm not even going to start speculating on what I think it is before you guys have a chance to look this log over. The beginning of the log is during the time the car was in what I call "sputter mode", it's like second personality that only comes out every so often. I pulled over let it idle while it was messed up so I could pop the hook and check my fuel pressure and just browse the engine to see if there was anything obvious like arcing plug wires because I haven't been able to catch it before on my logger or anything like that. Then the sputtering smoothly over a period of maybe 3 or 4 seconds disappeared and was replaced by the normal hum of my exhaust. That's when I stopped the log. The second log was when I started driving away. Right as I exited the parking lot the sputter abruptly came back and I scrambled madly for the datalogger and started logging. The second log has some sputtering in it but I'm not sure exactly what part of the log it was but I'm sure about the first one so take that one more heavily. The sputter is very hard to describe. While in "sputter mode" I can hit the gas and it just sounds like a hoopty missing really hard then as I'm on the gas the power smoothly comes back - the machine gun sound of a constant miss out of the tailpipe slowly gets quiter and quieter until you don't notice it any more. So you guys should be able to tell what is normal and what is not normal and where it was sputtering. Here are the logs, speculations anybody????
First log, idle only, beginning was sputtering, cured by the end:
TIMA FTRL FTRM FTRH FTO2 O2-R ISC TPS MAFS RPM KNCK INJP
12° 118.6% 124.8% 110.8% 125.6% 0.86V 47 9.4% 906 0 2.56ms
13° 118.6% 124.8% 110.8% 121.7% 0.86V 47 9.8% 875 0 2.56ms
11° 119.3% 124.8% 110.8% 117.8% 0.88V 45 9.8% 906 0 2.30ms
9° 119.3% 124.8% 110.8% 114.7% 0.92V 45 9.8% 906 0 2.30ms
13° 119.3% 124.8% 110.8% 111.5% 0.90V 45 9.8% 938 0 2.30ms
11° 119.3% 124.8% 110.8% 107.6% 0.90V 45 9.4% 938 0 2.05ms
8° 120.1% 124.8% 110.8% 104.5% 0.90V 35 9.8% 938 0 2.05ms
10° 120.1% 124.8% 110.8% 100.6% 0.90V 35 9.8% 938 0 2.05ms
10° 120.1% 124.8% 110.8% 97.5% 0.92V 35 9.8% 1031 0 2.05ms
10° 120.1% 124.8% 110.8% 94.4% 0.90V 28 9.8% 906 0 2.05ms
19° 119.3% 124.8% 110.8% 91.3% 0.88V 27 9.4% 781 0 2.05ms
16° 119.3% 124.8% 110.8% 88.9% 0.86V 27 9.8% 625 0 2.30ms
16° 119.3% 124.8% 110.8% 86.6% 0.88V 27 9.4% 656 0 2.30ms
16° 119.3% 124.8% 110.8% 84.2% 0.88V 36 9.8% 625 0 2.30ms
16° 119.3% 124.8% 110.8% 81.9% 0.78V 36 9.8% 719 0 2.05ms
11° 118.6% 124.8% 110.8% 78.8% 0.86V 36 9.4% 719 0 2.05ms
8° 118.6% 124.8% 110.8% 76.4% 0.84V 38 9.4% 688 0 2.05ms
9° 118.6% 124.8% 110.8% 73.3% 0.80V 38 9.4% 750 0 2.05ms
13° 118.6% 124.8% 110.8% 71.0% 0.72V 38 9.4% 750 0 2.05ms
10° 118.6% 124.8% 110.8% 68.6% 0.74V 38 9.4% 625 0 2.30ms
15° 117.8% 124.8% 110.8% 65.5% 0.74V 46 9.4% 625 0 2.56ms
16° 117.8% 124.8% 110.8% 64.0% 0.80V 46 9.4% 594 0 2.56ms
16° 117.8% 124.8% 110.8% 61.6% 0.80V 46 9.4% 625 0 2.56ms
16° 117.8% 124.8% 110.8% 59.3% 0.82V 46 9.4% 719 0 2.56ms
14° 117.8% 124.8% 110.8% 57.7% 0.78V 51 9.4% 750 0 2.56ms
5° 117.8% 124.8% 110.8% 54.6% 0.84V 51 9.4% 750 0 2.30ms
13° 117.8% 124.8% 110.8% 52.3% 0.80V 51 9.4% 781 0 2.30ms
7° 117.8% 124.8% 110.8% 49.1% 0.62V 54 9.4% 781 0 2.30ms
5° 117.8% 124.8% 110.8% 47.6% 0.41V 55 9.4% 688 0 2.30ms
8° 117.8% 124.8% 110.8% 49.1% 0.35V 55 9.4% 719 0 2.30ms
7° 117.8% 124.8% 110.8% 46.8% 0.39V 55 9.4% 719 0 2.30ms
7° 117.8% 124.8% 110.8% 48.4% 0.20V 58 9.4% 750 0 2.56ms
7° 117.8% 124.8% 110.8% 49.9% 0.16V 58 9.4% 813 0 2.56ms
10° 117.8% 124.8% 110.8% 51.5% 0.18V 58 9.4% 875 0 2.56ms
4° 117.8% 124.8% 110.8% 53.8% 0.23V 57 9.4% 875 0 2.30ms
7° 117.8% 124.8% 110.8% 55.4% 0.18V 56 9.4% 906 0 2.30ms
7° 117.8% 124.8% 110.8% 57.7% 0.16V 56 9.4% 938 0 2.30ms
7° 117.8% 124.8% 110.8% 56.9% 0.72V 56 9.4% 1000 0 2.30ms
9° 117.8% 124.8% 110.8% 53.0% 0.66V 47 9.4% 31.5Hz 969 0 2.30ms
10° 117.8% 124.8% 110.8% 49.1% 0.80V 45 9.4% 31.5Hz 1063 0 2.30ms
12° 117.8% 124.8% 110.8% 46.0% 0.86V 45 9.4% 31.5Hz 1000 0 2.05ms
13° 117.8% 124.8% 110.8% 42.1% 0.88V 45 9.4% 25.2Hz 1031 0 2.05ms
14° 117.8% 124.8% 110.8% 38.2% 0.88V 33 9.4% 25.2Hz 1000 0 2.05ms
14° 117.8% 124.8% 110.8% 34.3% 0.88V 33 9.4% 25.2Hz 1000 0 2.05ms
15° 117.8% 124.8% 110.8% 32.8% 0.90V 33 9.4% 25.2Hz 969 0 2.05ms
15° 117.8% 124.8% 110.8% 32.8% 0.92V 25 9.4% 25.2Hz 906 0 2.05ms
18° 117.8% 124.8% 110.8% 32.8% 0.90V 25 9.4% 25.2Hz 875 0 2.05ms
17° 117.8% 124.8% 110.8% 32.8% 0.90V 25 9.4% 25.2Hz 781 0 2.30ms
16° 117.8% 124.8% 110.8% 32.8% 0.92V 25 9.4% 25.2Hz 750 0 2.30ms
12° 117.8% 124.8% 110.8% 32.8% 0.90V 27 9.4% 18.9Hz 656 0 2.30ms
13° 117.8% 124.8% 110.8% 32.8% 0.88V 27 9.4% 18.9Hz 719 0 2.30ms
16° 117.8% 124.8% 110.8% 32.8% 0.90V 27 9.4% 25.2Hz 750 0 2.05ms
8° 117.0% 124.8% 110.8% 32.8% 0.90V 28 9.4% 18.9Hz 750 0 2.05ms
6° 117.0% 124.8% 110.8% 32.8% 0.90V 28 9.4% 18.9Hz 813 0 1.79ms
4° 117.0% 124.8% 110.8% 32.8% 0.90V 28 9.4% 18.9Hz 750 0 1.79ms
6° 117.0% 124.8% 110.8% 32.8% 0.88V 28 9.4% 18.9Hz 781 0 1.79ms
12° 116.2% 124.8% 110.8% 32.0% 0.88V 29 9.4% 18.9Hz 719 0 2.05ms
9° 116.2% 124.8% 110.8% 32.8% 0.86V 29 9.4% 18.9Hz 656 0 2.05ms
16° 116.2% 124.8% 110.8% 32.8% 0.82V 29 9.4% 18.9Hz 719 0 2.05ms
16° 116.2% 124.8% 110.8% 32.8% 0.88V 31 9.4% 18.9Hz 719 0 2.05ms
12° 116.2% 124.8% 110.8% 32.8% 0.82V 31 9.4% 18.9Hz 688 0 2.05ms
16° 115.4% 124.8% 110.8% 32.8% 0.80V 31 9.4% 18.9Hz 688 0 1.79ms
16° 115.4% 124.8% 110.8% 32.8% 0.55V 38 9.4% 18.9Hz 656 0 2.05ms
14° 115.4% 124.8% 110.8% 33.5% 0.25V 38 9.4% 18.9Hz 688 0 2.05ms
14° 115.4% 124.8% 110.8% 35.1% 0.06V 38 9.4% 18.9Hz 656 0 2.05ms
15° 114.7% 124.8% 110.8% 36.7% 0.02V 38 9.4% 18.9Hz 719 0 2.05ms
16° 114.7% 124.8% 110.8% 38.2% 0.00V 42 9.4% 18.9Hz 625 0 2.05ms
16° 114.7% 124.8% 110.8% 39.8% 0.00V 42 9.4% 18.9Hz 594 0 2.05ms
16° 114.7% 124.8% 110.8% 41.3% 0.00V 42 9.4% 18.9Hz 563 0 2.05ms
16° 113.9% 124.8% 110.8% 42.9% 0.00V 48 9.4% 18.9Hz 594 0 2.05ms
16° 113.9% 124.8% 110.8% 43.7% 0.00V 55 9.4% 18.9Hz 625 0 2.30ms
16° 113.9% 124.8% 110.8% 45.2% 0.00V 55 9.4% 18.9Hz 625 0 2.30ms
16° 113.9% 124.8% 110.8% 46.8% 0.00V 55 9.4% 18.9Hz 625 0 2.30ms
16° 113.9% 124.8% 110.8% 48.4% 0.00V 64 9.4% 18.9Hz 625 0 2.30ms
16° 113.1% 124.8% 110.8% 49.9% 0.00V 64 9.4% 18.9Hz 656 0 2.30ms
15° 113.1% 124.8% 110.8% 51.5% 0.00V 64 9.4% 25.2Hz 719 0 2.30ms
11° 113.1% 124.8% 110.8% 53.0% 0.00V 64 9.4% 25.2Hz 719 0 2.30ms
8° 113.1% 124.8% 110.8% 54.6% 0.00V 65 9.4% 18.9Hz 781 0 2.30ms
9° 113.1% 124.8% 110.8% 56.9% 0.00V 65 9.4% 25.2Hz 750 0 2.30ms
4° 112.3% 124.8% 110.8% 58.5% 0.00V 65 9.4% 18.9Hz 781 0 2.30ms
5° 112.3% 124.8% 110.8% 60.8% 0.00V 66 9.4% 18.9Hz 750 0 2.30ms
6° 112.3% 124.8% 110.8% 62.4% 0.00V 66 9.4% 25.2Hz 781 0 2.30ms
6° 112.3% 124.8% 110.8% 64.0% 0.02V 66 9.4% 25.2Hz 813 0 2.30ms
10° 111.5% 124.8% 110.8% 66.3% 0.00V 66 9.4% 25.2Hz 813 0 2.30ms
9° 111.5% 124.8% 110.8% 68.6% 0.00V 65 9.4% 25.2Hz 813 0 2.05ms
8° 111.5% 124.8% 110.8% 70.2% 0.00V 65 9.4% 25.2Hz 844 0 2.30ms
8° 111.5% 124.8% 110.8% 72.5% 0.02V 65 9.4% 25.2Hz 875 0 2.05ms
10° 111.5% 124.8% 110.8% 74.9% 0.02V 63 9.4% 25.2Hz 844 0 2.30ms
11° 110.8% 124.8% 110.8% 77.2% 0.02V 63 9.4% 25.2Hz 875 0 2.30ms
8° 110.8% 124.8% 110.8% 79.6% 0.02V 63 9.4% 25.2Hz 875 0 2.30ms
11° 110.8% 124.8% 110.8% 81.9% 0.02V 62 9.4% 25.2Hz 938 0 2.05ms
11° 110.8% 124.8% 110.8% 83.5% 0.04V 58 9.4% 25.2Hz 906 0 2.05ms
10° 110.0% 124.8% 110.8% 85.8% 0.02V 58 9.4% 25.2Hz 938 0 2.05ms
9° 110.0% 124.8% 110.8% 88.1% 0.04V 58 9.4% 25.2Hz 969 0 2.05ms
8° 110.0% 124.8% 110.8% 90.5% 0.06V 51 9.4% 25.2Hz 969 0 2.05ms
10° 110.0% 124.8% 110.8% 92.8% 0.72V 51 9.4% 25.2Hz 1000 0 2.05ms
9° 109.2% 124.8% 110.8% 88.9% 0.82V 51 9.4% 25.2Hz 1031 0 1.79ms
12° 109.2% 124.8% 110.8% 84.2% 0.70V 42 9.4% 18.9Hz 1000 0 1.79ms
13° 109.2% 124.8% 110.8% 84.2% 0.12V 40 9.4% 18.9Hz 1000 0 1.79ms
15° 109.2% 124.8% 110.8% 86.6% 0.04V 40 9.4% 18.9Hz 906 0 1.79ms
14° 108.4% 124.8% 110.8% 88.9% 0.06V 40 9.4% 18.9Hz 906 0 1.79ms
14° 108.4% 124.8% 110.8% 91.3% 0.02V 35 9.4% 18.9Hz 875 0 1.79ms
12° 108.4% 124.8% 110.8% 92.8% 0.02V 35 9.4% 18.9Hz 875 0 1.79ms
10° 108.4% 124.8% 110.8% 95.2% 0.02V 35 9.4% 18.9Hz 844 0 1.79ms
11° 108.4% 124.8% 110.8% 97.5% 0.02V 34 9.4% 18.9Hz 813 0 1.79ms
12° 107.6% 124.8% 110.8% 99.1% 0.02V 34 9.4% 18.9Hz 813 0 1.79ms
10° 107.6% 124.8% 110.8% 100.6% 0.02V 34 9.4% 18.9Hz 750 0 2.05ms
11° 108.4% 124.8% 110.8% 103.0% 0.02V 34 9.4% 18.9Hz 781 0 2.05ms
13° 108.4% 124.8% 110.8% 104.5% 0.02V 37 9.4% 18.9Hz 750 0 2.05ms
7° 108.4% 124.8% 110.8% 106.1% 0.02V 37 9.4% 18.9Hz 750 0 2.05ms
10° 108.4% 124.8% 110.8% 108.4% 0.02V 37 9.4% 18.9Hz 719 0 2.05ms
8° 108.4% 124.8% 110.8% 110.0% 0.02V 39 9.4% 18.9Hz 781 0 2.05ms
10° 109.2% 124.8% 110.8% 111.5% 0.02V 39 9.4% 18.9Hz 813 0 2.05ms
9° 109.2% 124.8% 110.8% 113.9% 0.02V 39 9.4% 18.9Hz 781 0 2.05ms
6° 109.2% 124.8% 110.8% 115.4% 0.02V 39 9.4% 18.9Hz 813 0 2.05ms
6° 109.2% 124.8% 110.8% 117.8% 0.02V 38 9.4% 18.9Hz 781 0 2.05ms
8° 110.0% 124.8% 110.8% 119.3% 0.02V 38 9.4% 18.9Hz 813 0 2.05ms
7° 110.0% 124.8% 110.8% 120.9% 0.02V 38 9.4% 18.9Hz 781 0 2.05ms
9° 110.0% 124.8% 110.8% 123.2% 0.02V 38 9.4% 18.9Hz 750 0 2.05ms
10° 110.0% 124.8% 110.8% 125.6% 0.02V 38 9.4% 18.9Hz 781 0 2.05ms
9° 110.0% 124.8% 110.8% 127.1% 0.02V 38 9.4% 18.9Hz 813 0 2.05ms
11° 110.8% 124.8% 110.8% 129.5% 0.02V 39 9.4% 18.9Hz 813 0 2.05ms
11° 110.8% 124.8% 110.8% 131.0% 0.02V 39 9.4% 18.9Hz 813 0 2.05ms
10° 110.8% 124.8% 110.8% 133.4% 0.02V 39 9.4% 18.9Hz 813 0 2.05ms
8° 110.8% 124.8% 110.8% 134.9% 0.02V 38 9.4% 18.9Hz 813 0 2.05ms
8° 111.5% 124.8% 110.8% 137.3% 0.02V 38 9.4% 18.9Hz 813 0 2.05ms
9° 111.5% 124.8% 110.8% 138.8% 0.08V 38 9.4% 18.9Hz 813 0 2.05ms
8° 111.5% 124.8% 110.8% 139.6% 0.80V 38 9.4% 18.9Hz 844 0 2.05ms
9° 111.5% 124.8% 110.8% 136.5% 0.88V 35 9.4% 18.9Hz 875 0 2.05ms
8° 111.5% 124.8% 110.8% 132.6% 0.84V 35 9.4% 18.9Hz 906 0 1.79ms
8° 112.3% 124.8% 110.8% 128.7% 0.74V 35 9.4% 18.9Hz 906 0 1.79ms
9° 112.3% 124.8% 110.8% 125.6% 0.55V 31 9.8% 18.9Hz 906 0 1.79ms
10° 112.3% 124.8% 110.8% 124.0% 0.43V 31 9.4% 18.9Hz 906 0 1.79ms
11° 112.3% 124.8% 110.8% 126.4% 0.20V 31 9.8% 18.9Hz 875 0 1.79ms
12° 113.1% 124.8% 110.8% 128.7% 0.06V 31 9.8% 18.9Hz 875 0 1.79ms
11° 113.1% 124.8% 110.8% 130.3% 0.06V 28 9.4% 18.9Hz 875 0 1.79ms
11° 113.1% 124.8% 110.8% 132.6% 0.14V 28 9.8% 18.9Hz 875 0 1.79ms
11° 113.1% 124.8% 110.8% 132.6% 0.82V 28 9.4% 18.9Hz 844 0 1.79ms
12° 113.1% 124.8% 110.8% 129.5% 0.82V 26 9.8% 18.9Hz 844 0 1.79ms
11° 113.9% 124.8% 110.8% 126.4% 0.82V 26 9.8% 18.9Hz 813 0 1.79ms
12° 113.9% 124.8% 110.8% 123.2% 0.80V 26 9.4% 18.9Hz 813 0 1.79ms
10° 113.9% 124.8% 110.8% 120.1% 0.82V 26 9.8% 18.9Hz 813 0 1.79ms
9° 113.9% 124.8% 110.8% 117.0% 0.80V 26 9.8% 18.9Hz 813 0 1.79ms
10° 114.7% 124.8% 110.8% 113.9% 0.80V 26 9.4% 18.9Hz 813 0 1.79ms
9° 114.7% 124.8% 110.8% 110.8% 0.78V 26 9.8% 18.9Hz 781 0 1.79ms
10° 114.7% 124.8% 110.8% 108.4% 0.68V 26 9.4% 18.9Hz 781 0 1.79ms
9° 114.7% 124.8% 110.8% 105.3% 0.35V 27 9.8% 18.9Hz 781 0 1.79ms
9° 115.4% 124.8% 110.8% 106.9% 0.12V 27 9.8% 18.9Hz 781 0 1.79ms
9° 115.4% 124.8% 110.8% 109.2% 0.06V 27 9.8% 18.9Hz 781 0 1.79ms
9° 115.4% 124.8% 110.8% 110.8% 0.08V 27 9.4% 18.9Hz 813 0 1.79ms
9° 115.4% 124.8% 110.8% 113.1% 0.10V 27 9.4% 18.9Hz 781 0 1.79ms
9° 115.4% 124.8% 110.8% 114.7% 0.08V 27 9.8% 18.9Hz 781 0 1.79ms
9° 116.2% 124.8% 110.8% 116.2% 0.06V 27 9.4% 18.9Hz 813 0 1.79ms
9° 116.2% 124.8% 110.8% 118.6% 0.10V 27 9.8% 18.9Hz 781 0 1.79ms
9° 116.2% 124.8% 110.8% 120.9% 0.16V 27 9.8% 18.9Hz 781 0 1.79ms
9° 116.2% 124.8% 110.8% 121.7% 0.53V 27 9.8% 18.9Hz 813 0 1.79ms
9° 117.0% 124.8% 110.8% 118.6% 0.76V 27 9.4% 18.9Hz 781 0 1.79ms
9° 117.0% 124.8% 110.8% 115.4% 0.53V 27 9.4% 18.9Hz 781 0 1.79ms
9° 117.0% 124.8% 110.8% 112.3% 0.64V 27 9.8% 18.9Hz 781 0 1.79ms
9° 117.0% 124.8% 110.8% 113.1% 0.20V 27 9.4% 18.9Hz 781 0 1.79ms
9° 117.0% 124.8% 110.8% 114.7% 0.12V 27 9.8% 18.9Hz 781 0 1.79ms
9° 117.8% 124.8% 110.8% 117.0% 0.10V 27 9.8% 18.9Hz 813 0 1.79ms
9° 117.8% 124.8% 110.8% 119.3% 0.12V 27 9.4% 18.9Hz 781 0 1.79ms
9° 117.8% 124.8% 110.8% 120.9% 0.14V 27 9.4% 18.9Hz 813 0 1.79ms
9° 117.8% 124.8% 110.8% 123.2% 0.21V 27 9.8% 18.9Hz 813 0 1.79ms
9° 118.6% 124.8% 110.8% 121.7% 0.84V 27 9.4% 18.9Hz 813 0 1.79ms
9° 118.6% 124.8% 110.8% 118.6% 0.84V 27 9.4% 18.9Hz 813 0 1.79ms
9° 118.6% 124.8% 110.8% 115.4% 0.82V 27 9.4% 18.9Hz 813 0 1.79ms
10° 118.6% 124.8% 110.8% 113.1% 0.78V 27 9.8% 18.9Hz 813 0 1.79ms
9° 118.6% 124.8% 110.8% 110.0% 0.62V 28 9.8% 18.9Hz 781 0 1.79ms
11° 119.3% 124.8% 110.8% 107.6% 0.59V 28 9.8% 18.9Hz 781 0 1.79ms
9° 119.3% 124.8% 110.8% 107.6% 0.18V 28 9.8% 18.9Hz 781 0 1.79ms
9° 119.3% 124.8% 110.8% 110.0% 0.10V 28 9.4% 18.9Hz 813 0 1.79ms
7° 119.3% 124.8% 110.8% 111.5% 0.16V 28 9.8% 18.9Hz 813 0 1.79ms
8° 120.1% 124.8% 110.8% 112.3% 0.66V 28 9.8% 18.9Hz 813 0 1.79ms
9° 120.1% 124.8% 110.8% 110.8% 0.59V 28 9.4% 18.9Hz 781 0 1.79ms
10° 120.1% 124.8% 110.8% 111.5% 0.16V 28 9.4% 18.9Hz 813 0 1.79ms
9° 120.1% 124.8% 110.8% 113.9% 0.14V 28 9.4% 18.9Hz 813 0 1.79ms
10° 120.9% 124.8% 110.8% 115.4% 0.25V 28 9.8% 18.9Hz 813 0 1.79ms
9° 120.9% 124.8% 110.8% 114.7% 0.80V 28 9.8% 18.9Hz 813 0 1.79ms
10° 120.9% 124.8% 110.8% 111.5% 0.76V 28 9.4% 18.9Hz 813 0 1.79ms
10° 120.9% 124.8% 110.8% 110.0% 0.23V 28 9.4% 18.9Hz 813 0 1.79ms
9° 120.9% 124.8% 110.8% 111.5% 0.14V 28 9.8% 18.9Hz 813 0 1.79ms
9° 121.7% 124.8% 110.8% 113.1% 0.16V 28 9.4% 18.9Hz 813 0 1.79ms
8° 121.7% 124.8% 110.8% 113.9% 0.76V 28 9.4% 18.9Hz 813 0 1.79ms
9° 121.7% 124.8% 110.8% 110.8% 0.78V 28 9.8% 18.9Hz 813 0 1.79ms
9° 121.7% 124.8% 110.8% 108.4% 0.45V 28 9.8% 18.9Hz 781 0 1.79ms
9° 122.5% 124.8% 110.8% 110.0% 0.12V 28 9.4% 18.9Hz 813 0 1.79ms
9° 122.5% 124.8% 110.8% 112.3% 0.10V 28 9.4% 18.9Hz 813 0 1.79ms
8° 122.5% 124.8% 110.8% 113.9% 0.16V 28 9.8% 18.9Hz 813 0 1.79ms
9° 122.5% 124.8% 110.8% 114.7% 0.74V 27 9.8% 18.9Hz 844 0 1.79ms
7° 122.5% 124.8% 110.8% 111.5% 0.80V 27 9.4% 18.9Hz 813 0 1.79ms
9° 123.2% 124.8% 110.8% 109.2% 0.47V 27 9.4% 18.9Hz 781 0 1.79ms
10° 123.2% 124.8% 110.8% 110.0% 0.16V 27 9.4% 18.9Hz 813 0 1.79ms
9° 123.2% 124.8% 110.8% 111.5% 0.14V 27 9.8% 18.9Hz 813 0 1.79ms
9° 123.2% 124.8% 110.8% 111.5% 0.76V 27 9.8% 18.9Hz 781 0 1.79ms
10° 124.0% 124.8% 110.8% 109.2% 0.76V 27 9.8% 18.9Hz 813 0 1.79ms
8° 124.0% 124.8% 110.8% 106.1% 0.72V 27 9.8% 18.9Hz 781 0 1.79ms
10° 124.0% 124.8% 110.8% 103.0% 0.66V 27 9.8% 18.9Hz 781 0 1.79ms
9° 124.0% 124.8% 110.8% 103.7% 0.16V 27 9.4% 18.9Hz 813 0 1.79ms
10° 124.8% 124.8% 110.8% 106.1% 0.16V 27 9.4% 18.9Hz 813 0 1.79ms
9° 124.8% 124.8% 110.8% 108.4% 0.33V 27 9.8% 18.9Hz 813 0 1.79ms
10° 124.8% 124.8% 110.8% 106.1% 0.72V 27 9.4% 18.9Hz 781 0 1.79ms
9° 124.8% 124.8% 110.8% 103.7% 0.27V 27 9.4% 18.9Hz 813 0 1.79ms
8° 124.8% 124.8% 110.8% 105.3% 0.14V 27 9.8% 18.9Hz 813 0 1.79ms
9° 125.6% 124.8% 110.8% 107.6% 0.14V 27 9.8% 18.9Hz 813 0 1.79ms
9° 125.6% 124.8% 110.8% 109.2% 0.14V 27 9.4% 18.9Hz 813 0 1.79ms
8° 125.6% 124.8% 110.8% 111.5% 0.14V 27 9.8% 18.9Hz 781 0 1.79ms
9° 125.6% 124.8% 110.8% 113.1% 0.70V 27 9.4% 18.9Hz 813 0 1.79ms
8° 126.4% 124.8% 110.8% 110.0% 0.78V 27 9.4% 18.9Hz 781 0 1.79ms
10° 126.4% 124.8% 110.8% 106.9% 0.72V 27 9.8% 18.9Hz 781 0 1.79ms
10° 126.4% 124.8% 110.8% 104.5% 0.68V 27 9.8% 18.9Hz 781 0 1.79ms
9° 126.4% 124.8% 110.8% 103.0% 0.39V 27 9.8% 18.9Hz 781 0 1.79ms
10° 126.4% 124.8% 110.8% 105.3% 0.10V 27 9.8% 18.9Hz 813 0 1.79ms
8° 127.1% 124.8% 110.8% 107.6% 0.06V 27 9.4% 18.9Hz 813 0 1.79ms
8° 127.1% 124.8% 110.8% 109.2% 0.12V 27 9.8% 18.9Hz 813 0 1.79ms
8° 127.1% 124.8% 110.8% 110.8% 0.53V 27 9.8% 18.9Hz 813 0 1.79ms
9° 127.1% 124.8% 110.8% 108.4% 0.80V 27 9.8% 18.9Hz 813 0 1.79ms
9° 127.9% 124.8% 110.8% 106.1% 0.74V 27 9.8% 18.9Hz 813 0 1.79ms
9° 127.9% 124.8% 110.8% 102.2% 0.43V 27 9.4% 18.9Hz 781 0 1.79ms
10° 127.9% 124.8% 110.8% 103.0% 0.23V 27 9.4% 18.9Hz 813 0 1.79ms
8° 127.9% 124.8% 110.8% 105.3% 0.14V 27 9.8% 18.9Hz 813 0 1.79ms
9° 128.7% 124.8% 110.8% 106.9% 0.14V 27 9.4% 18.9Hz 813 0 1.79ms
9° 128.7% 124.8% 110.8% 109.2% 0.14V 27 9.8% 18.9Hz 813 0 1.79ms
9° 128.7% 124.8% 110.8% 110.8% 0.62V 26 9.4% 18.9Hz 813 0 1.79ms
9° 128.7% 124.8% 110.8% 107.6% 0.82V 26 9.8% 18.9Hz 813 0 1.79ms
10° 128.7% 124.8% 110.8% 104.5% 0.78V 26 9.8% 18.9Hz 813 0 1.79ms
10° 129.5% 124.8% 110.8% 102.2% 0.78V 26 9.4% 18.9Hz 813 0 1.79ms
Second Log, sputtering while driving
8° 134.9% 124.8% 110.8% 103.0% 0.06V 26 9.8% 18.9Hz 781 0 1.79ms
9° 134.9% 124.8% 110.8% 104.5% 0.10V 26 9.4% 18.9Hz 781 0 1.79ms
9° 134.9% 124.8% 110.8% 106.9% 0.18V 26 9.8% 18.9Hz 813 0 1.79ms
8° 134.9% 124.8% 110.8% 106.9% 0.82V 26 9.8% 18.9Hz 813 0 1.79ms
10° 135.7% 124.8% 110.8% 103.0% 0.84V 26 9.8% 18.9Hz 813 0 1.79ms
9° 135.7% 124.8% 110.8% 99.8% 0.82V 26 9.8% 18.9Hz 813 0 1.79ms
9° 135.7% 124.8% 110.8% 97.5% 0.80V 26 9.8% 18.9Hz 813 0 1.79ms
10° 135.7% 124.8% 110.8% 0.04V 27 9.4% 18.9Hz 719 0 2.05ms
12° 134.9% 124.8% 110.8% 98.3% 0.00V 27 9.4% 18.9Hz 750 0 2.05ms
0.76V 34 9.8% 18.9Hz 813 64 2.05ms
9° 134.9% 124.8% 110.8% 95.9% 0.72V 34 9.8% 18.9Hz 813 0 2.05ms
9° 134.9% 124.8% 110.8% 92.0% 0.49V 34 9.8% 18.9Hz 813 0 2.05ms
10° 134.9% 124.8% 110.8% 34 9.8% 18.9Hz 813 0 2.05ms
7° 134.2% 124.8% 110.8% 100.6% 0.16V 33 9.8% 18.9Hz 844 0 2.05ms
9° 134.2% 124.8% 110.8% 103.0% 0.62V 33 9.8% 18.9Hz 844 0 2.05ms
9° 134.2% 124.8% 110.8% 101.4% 0.20V 33 9.8% 18.9Hz 844 0 2.05ms
10° 134.2% 124.8% 110.8% 103.7% 0.08V 31 9.8% 18.9Hz 844 0 2.05ms
10° 134.9% 124.8% 110.8% 106.1% 0.08V 31 9.8% 18.9Hz 844 0 2.05ms
10° 134.9% 124.8% 110.8% 107.6% 0.14V 31 9.8% 18.9Hz 844 0 2.05ms
10° 134.9% 124.8% 110.8% 110.0% 0.25V 31 9.8% 18.9Hz 844 0 2.05ms
10° 134.9% 124.8% 110.8% 107.6% 0.82V 31 9.8% 18.9Hz 844 0 2.05ms
11° 134.9% 124.8% 110.8% 104.5% 0.76V 30 9.8% 18.9Hz 813 0 2.05ms
9° 135.7% 124.8% 110.8% 101.4% 0.76V 45 13.7% 25.2Hz 813 0 2.82ms
9° 135.7% 124.8% 110.8% 100.6% 0.06V 55 13.7% 31.5Hz 969 0 3.07ms
16° 135.7% 124.8% 110.8% 104.5% 0.08V 69 14.9% 44.0Hz 1344 0 2.82ms
26° 135.7% 124.8% 110.8% 113.9% 0.45V 68 9.8% 44.0Hz 1594 0 2.56ms
20° 135.7% 124.8% 110.8% 105.3% 0.94V 63 10.6% 37.7Hz 1531 0 2.05ms
25° 135.7% 124.8% 110.8% 94.4% 0.92V 51 9.8% 25.2Hz 1563 0 1.54ms
25° 135.7% 124.8% 110.8% 83.5% 0.90V 36 9.8% 18.9Hz 1500 0 1.28ms
23° 135.7% 124.8% 110.8% 99.8% 0.86V 36 9.8% 18.9Hz 1219 0 0.00ms
23° 135.7% 124.8% 110.8% 103.0% 0.00V 36 9.8% 18.9Hz 906 0 1.79ms
19° 135.7% 124.8% 110.8% 108.4% 0.00V 36 9.8% 18.9Hz 844 0 1.79ms
18° 135.7% 124.8% 110.8% 113.1% 0.02V 36 9.8% 18.9Hz 875 0 2.05ms
14° 135.7% 124.8% 110.8% 117.8% 0.16V 36 9.8% 18.9Hz 875 0 2.05ms
11° 135.7% 124.8% 110.8% 116.2% 0.86V 36 9.8% 18.9Hz 844 0 2.05ms
12° 135.7% 124.8% 110.8% 111.5% 0.84V 34 9.8% 18.9Hz 875 0 1.28ms
11° 135.7% 124.8% 110.8% 106.1% 0.86V 57 18.8% 50.3Hz 1156 0 3.58ms
17° 135.7% 124.8% 110.8% 95.2% 0.90V 71 19.2% 50.3Hz 1375 0 3.33ms
26° 135.7% 124.8% 110.8% 94.4% 0.02V 81 20.4% 62.9Hz 1219 0 4.35ms
20° 135.7% 124.8% 110.8% 105.3% 0.02V 83 20.8% 62.9Hz 1156 0 4.61ms
18° 135.7% 124.8% 110.8% 114.7% 0.04V 83 20.8% 62.9Hz 1094 0 4.61ms
15° 135.7% 124.8% 110.8% 123.2% 0.06V 83 20.8% 62.9Hz 1125 0 4.86ms
20° 135.7% 124.8% 110.8% 126.4% 0.84V 83 20.4% 75.5Hz 1438 0 4.10ms
24° 135.7% 124.8% 110.8% 113.1% 0.70V 83 20.4% 81.8Hz 1719 0 4.10ms
27° 135.7% 124.8% 110.8% 121.7% 0.60V 71 20.8% 81.8Hz 1906 0 3.58ms
30° 135.7% 124.8% 110.8% 103.7% 0.84V 82 22.4% 88.1Hz 2156 0 3.58ms
30° 135.7% 124.8% 110.8% 96.7% 0.08V 73 24.7% 106.9Hz 2406 0 4.10ms
30° 135.7% 124.8% 110.8% 123.2% 0.04V 76 27.1% 132.1Hz 2688 0 4.61ms
31° 135.7% 124.8% 110.8% 128.7% 0.88V 79 29.0% 163.5Hz 3094 0 4.61ms
30° 135.7% 124.8% 110.8% 94.4% 0.88V 79 29.8% 182.4Hz 3469 0 4.35ms
31° 135.7% 124.8% 110.8% 88.9% 0.02V 78 25.5% 163.5Hz 3688 0 3.58ms
36° 135.7% 124.8% 110.8% 127.1% 0.02V 72 23.1% 113.2Hz 3875 0 2.82ms
40° 135.7% 124.8% 110.8% 159.9% 0.00V 70 22.4% 100.6Hz 3906 0 2.56ms
41° 135.7% 124.8% 110.8% 166.9% 0.68V 65 18.0% 62.9Hz 4000 0 1.79ms
41° 135.7% 124.8% 110.8% 136.5% 0.90V 62 16.5% 50.3Hz 3875 0 1.54ms
41° 135.7% 124.8% 110.8% 106.9% 0.86V 57 15.3% 62.9Hz 3875 0 1.79ms
41° 135.7% 124.8% 110.8% 75.7% 0.86V 47 12.5% 56.6Hz 3781 0 1.54ms
40° 135.7% 124.8% 110.8% 48.4% 0.72V 36 9.8% 50.3Hz 3594 0 1.54ms
40° 135.7% 124.8% 110.8% 36.7% 0.47V 36 9.8% 44.0Hz 3406 0 1.54ms
40° 135.7% 124.8% 110.8% 99.8% 0.53V 36 9.8% 37.7Hz 3219 0 1.54ms
34° 135.7% 124.8% 110.8% 84.2% 0.86V 58 15.7% 44.0Hz 3156 0 1.54ms
39° 135.7% 124.8% 110.8% 60.8% 0.74V 68 20.4% 75.5Hz 3125 0 2.30ms
38° 135.7% 124.8% 110.8% 73.3% 0.00V 71 23.5% 94.4Hz 3063 0 3.07ms
36° 135.7% 124.8% 110.8% 98.3% 0.00V 74 25.5% 119.5Hz 3219 0 3.58ms
35° 135.7% 124.8% 110.8% 132.6% 0.06V 70 22.4% 100.6Hz 3313 0 3.07ms
38° 135.7% 124.8% 110.8% 142.7% 0.60V 70 22.4% 100.6Hz 3375 0 2.82ms
39° 135.7% 124.8% 110.8% 153.7% 0.18V 69 21.2% 88.1Hz 3500 0 2.56ms
40° 135.7% 124.8% 110.8% 149.8% 0.64V 67 20.0% 75.5Hz 3563 0 2.30ms
40° 135.7% 124.8% 110.8% 163.0% 0.12V 67 20.0% 75.5Hz 3594 0 2.30ms
40° 135.7% 124.8% 110.8% 166.1% 0.35V 67 20.0% 75.5Hz 3594 0 2.30ms
40° 135.7% 124.8% 110.8% 154.4% 0.59V 67 20.0% 75.5Hz 3688 0 2.30ms
40° 135.7% 124.8% 110.8% 146.6% 0.57V 67 20.0% 75.5Hz 3688 0 2.30ms
40° 135.7% 124.8% 110.8% 166.9% 0.59V 67 20.0% 75.5Hz 3656 0 2.30ms
40° 135.7% 124.8% 110.8% 166.1% 0.25V 67 20.0% 75.5Hz 3688 0 2.30ms
40° 135.7% 124.8% 110.8% 156.0% 0.25V 68 20.4% 81.8Hz 3719 0 2.30ms
40° 135.7% 124.8% 110.8% 163.8% 0.59V 68 20.4% 81.8Hz 3688 0 2.56ms
40° 135.7% 124.8% 110.8% 159.9% 0.53V 68 20.4% 81.8Hz 3750 0 2.56ms
40° 135.7% 124.8% 110.8% 159.9% 0.62V 68 20.8% 81.8Hz 3750 0 2.56ms
41° 135.7% 124.8% 110.8% 166.9% 0.62V 62 10.2% 37.7Hz 3688 0 1.54ms
40° 135.7% 124.8% 110.8% 139.6% 0.72V 39 9.8% 50.3Hz 3156 0 2.05ms
39° 135.7% 124.8% 110.8% 119.3% 0.51V 45 16.9% 50.3Hz 2625 0 2.30ms
37° 135.7% 124.8% 110.8% 117.8% 0.72V 70 22.0% 75.5Hz 2063 0 3.58ms
31° 135.7% 124.8% 110.8% 130.3% 0.02V 73 25.1% 94.4Hz 2125 0 4.35ms
29° 135.7% 124.8% 110.8% 153.7% 0.02V 74 23.9% 100.6Hz 2250 0 4.35ms
30° 135.7% 124.8% 110.8% 166.9% 0.53V 70 22.4% 94.4Hz 2281 0 3.84ms
32° 135.7% 124.8% 110.8% 156.0% 0.18V 69 21.6% 88.1Hz 2344 0 3.58ms
32° 135.7% 124.8% 110.8% 166.9% 0.10V 69 21.2% 88.1Hz 2406 0 3.58ms
33° 135.7% 124.8% 110.8% 158.3% 0.39V 68 20.8% 81.8Hz 2469 0 3.33ms
135.7% 124.8% 110.8% 150.5% 0.70V 69 21.6% 88.1Hz 2594 0 3.33ms
34° 135.7% 124.8% 110.8% 131.0% 0.72V 69 21.6% 88.1Hz 2625 0 3.07ms
34° 135.7% 124.8% 110.8% 120.9% 0.49V 70 22.0% 94.4Hz 2688 0 3.07ms
34° 135.7% 124.8% 110.8% 115.4% 0.72V 70 22.0% 94.4Hz 2750 0 3.07ms
35° 135.7% 124.8% 110.8% 110.8% 0.23V 69 21.6% 94.4Hz 2813 0 3.07ms
35° 135.7% 124.8% 110.8% 109.2% 0.76V 69 21.2% 88.1Hz 2844 0 2.82ms
36° 135.7% 124.8% 110.8% 99.1% 0.16V 68 20.4% 81.8Hz 2875 0 2.56ms
37° 135.7% 124.8% 110.8% 96.7% 0.68V 77 16.5% 56.6Hz 2844 0 2.05ms
39° 135.7% 124.8% 110.8% 115.4% 0.00V 79 18.4% 62.9Hz 2875 0 2.56ms
38° 135.7% 124.8% 110.8% 138.8% 0.02V 86 31.0% 119.5Hz 2938 0 5.12ms
30° 135.7% 124.8% 110.8% 166.9% 0.04V 102 36.9% 182.4Hz 2969 0 5.89ms
27° 135.7% 124.8% 110.8% 146.6% 0.70V 102 36.9% 201.3Hz 3094 0 5.89ms
26° 135.7% 124.8% 110.8% 114.7% 0.64V 98 36.9% 213.9Hz 3219 0 5.89ms
27° 135.7% 124.8% 110.8% 114.7% 0.47V 87 36.5% 226.4Hz 3344 0 6.14ms
26° 135.7% 124.8% 110.8% 133.4% 0.66V 83 32.5% 220.2Hz 3406 0 5.63ms
28° 135.7% 124.8% 110.8% 134.9% 0.41V 83 32.2% 232.7Hz 3563 0 5.63ms
28° 135.7% 124.8% 110.8% 119.3% 0.43V 79 29.4% 207.6Hz 3719 0 4.86ms
31° 135.7% 124.8% 110.8% 153.7% 0.37V 79 29.0% 195.0Hz 3813 0 4.86ms
32° 135.7% 124.8% 110.8% 139.6% 0.70V 79 29.0% 188.7Hz 3938 0 4.35ms
33° 135.7% 124.8% 110.8% 95.9% 0.59V 79 29.0% 188.7Hz 4031 0 4.10ms
33° 135.7% 124.8% 110.8% 120.1% 0.80V 77 27.5% 163.5Hz 4156 0 3.58ms
35° 135.7% 124.8% 110.8% 132.6% 0.10V 76 27.1% 157.3Hz 4219 0 3.58ms
35° 135.7% 124.8% 110.8% 122.5% 0.88V 67 9.8% 94.4Hz 4156 0 1.54ms
40° 135.7% 124.8% 110.8% 92.0% 0.68V 45 9.8% 94.4Hz 3500 0 2.56ms
39° 135.7% 124.8% 110.8% 65.5% 0.66V 51 17.6% 88.1Hz 2875 0 2.30ms
36° 135.7% 124.8% 110.8% 44.5% 0.86V 68 21.6% 75.5Hz 2781 0 2.56ms
35° 135.7% 124.8% 110.8% 54.6% 0.02V 73 24.7% 113.2Hz 2781 0 3.58ms
33° 135.7% 124.8% 110.8% 87.4% 0.02V 73 24.7% 119.5Hz 2813 0
33° 135.7% 124.8% 110.8% 79.6% 0.57V 72 23.9% 113.2Hz 2875 0 3.58ms
34° 135.7% 124.8% 110.8% 108.4% 0.31V 72 23.5% 113.2Hz 2906 0 3.33ms
35° 135.7% 124.8% 110.8% 88.1% 0.49V 72 23.5% 113.2Hz 2938 0 3.33ms
35° 135.7% 124.8% 110.8% 103.0% 0.84V 71 22.4% 100.6Hz 2969 0 3.07ms
36° 135.7% 124.8% 110.8% 94.4% 0.14V 70 22.0% 94.4Hz 3000 0 3.07ms
36° 135.7% 124.8% 110.8% 103.7% 0.78V 69 21.6% 94.4Hz 2969 0 2.82ms
37° 135.7% 124.8% 110.8% 103.0% 0.14V 69 21.2% 88.1Hz 3031 0 2.82ms
37° 135.7% 124.8% 110.8% 103.0% 0.27V 70 22.4% 94.4Hz 3031 0 3.07ms
36° 135.7% 124.8% 110.8% 113.9% 0.82V 71 22.7% 100.6Hz 3031 0 3.07ms
36° 135.7% 124.8% 110.8% 92.0% 0.57V 71 22.7% 100.6Hz 3063 0 3.07ms
36° 135.7% 124.8% 110.8% 86.6% 0.62V 71 22.7% 100.6Hz 3063 0 3.07ms
36° 135.7% 124.8% 110.8% 99.8% 0.76V 71 22.7% 100.6Hz 3094 0 2.82ms
37° 135.7% 124.8% 110.8% 89.7% 0.18V 71 22.7% 100.6Hz 3094 0 2.82ms
37° 135.7% 124.8% 110.8% 85.8% 0.33V 70 22.0% 100.6Hz 3125 0 2.82ms
37° 135.7% 124.8% 110.8% 89.7% 0.60V 70 22.0% 94.4Hz 3125 0 2.82ms
37° 135.7% 124.8% 110.8% 95.2% 0.72V 69 21.6% 88.1Hz 3125 0 2.56ms
38° 135.7% 124.8% 110.8% 98.3% 0.76V 69 21.2% 88.1Hz 3125 0 2.56ms
38° 135.7% 124.8% 110.8% 94.4% 0.78V 68 20.4% 81.8Hz 3156 0 2.56ms
38° 135.7% 124.8% 110.8% 94.4% 0.80V 64 17.3% 62.9Hz 3156 0 1.79ms
39° 135.7% 124.8% 110.8% 74.9% 0.23V 63 16.9% 50.3Hz 3125 0 1.79ms
39° 135.7% 124.8% 110.8% 99.8% 0.16V 65 19.6% 62.9Hz 3125 0 2.30ms
39° 135.7% 124.8% 110.8% 106.9% 0.04V 68 20.4% 75.5Hz 3125 0 2.56ms
38° 135.7% 124.8% 110.8% 120.1% 0.82V 69 21.2% 88.1Hz 3125 0 2.56ms
38° 135.7% 124.8% 110.8% 97.5% 0.64V 69 22.0% 88.1Hz 3125 0 2.82ms
38° 135.7% 124.8% 110.8% 102.2% 0.80V 70 22.0% 88.1Hz 3125 0 2.56ms
38° 135.7% 124.8% 110.8% 92.0% 0.68V 70 22.0% 94.4Hz 3156 0 2.82ms
38° 135.7% 124.8% 110.8% 88.9% 0.25V 70 22.0% 94.4Hz 3188 0 2.82ms
37° 135.7% 124.8% 110.8% 103.0% 0.82V 70 22.4% 94.4Hz 3156 0 2.82ms
37° 135.7% 124.8% 110.8% 99.1% 0.53V 70 22.4% 94.4Hz 3156 0 2.82ms
37° 135.7% 124.8% 110.8% 92.0% 0.14V 70 22.4% 94.4Hz 3188 0 2.82ms
37° 135.7% 124.8% 110.8% 83.5% 0.35V 70 22.4% 94.4Hz 3188 0 2.82ms
37° 135.7% 124.8% 110.8% 106.9% 0.57V 70 22.4% 94.4Hz 3219 0 2.82ms
37° 135.7% 124.8% 110.8% 88.1% 0.35V 70 22.0% 94.4Hz 3219 0 2.56ms
38° 135.7% 124.8% 110.8% 89.7% 0.49V 69 21.2% 88.1Hz 3250 0 2.56ms
38° 135.7% 124.8% 110.8% 87.4% 0.21V 67 19.6% 75.5Hz 3250 0 2.05ms
39° 135.7% 124.8% 110.8% 90.5% 0.04V 67 19.6% 75.5Hz 3250 0 2.30ms
39° 135.7% 124.8% 110.8% 116.2% 0.06V 65 18.8% 69.2Hz 3250 0 2.05ms
39° 135.7% 124.8% 110.8% 117.8% 0.86V 63 16.9% 56.6Hz 3219 0 1.79ms
39° 135.7% 124.8% 110.8% 93.6% 0.88V 57 15.3% 44.0Hz 3188 0 1.54ms
39° 135.7% 124.8% 110.8% 69.4% 0.80V 57 15.3% 44.0Hz 3188 0 1.54ms
39° 135.7% 124.8% 110.8% 48.4% 0.27V 60 16.1% 44.0Hz 3156 0 1.54ms
39° 135.7% 124.8% 110.8% 72.5% 0.04V 64 17.6% 56.6Hz 3156 0 1.79ms
39° 135.7% 124.8% 110.8% 97.5% 0.04V 65 18.8% 62.9Hz 3156 0 2.30ms
39° 135.7% 124.8% 110.8% 120.9% 0.72V 66 19.2% 69.2Hz 3156 0 2.30ms
39° 135.7% 124.8% 110.8% 99.1% 0.78V 66 19.2% 69.2Hz 3156 0 2.05ms
39° 135.7% 124.8% 110.8% 85.0% 0.21V 66 19.2% 69.2Hz 3156 0 2.30ms
39° 135.7% 124.8% 110.8% 109.2% 0.14V 66 19.2% 69.2Hz 3125 0 2.30ms
39° 135.7% 124.8% 110.8% 97.5% 0.64V 66 19.2% 69.2Hz 3125 0 2.30ms
39° 135.7% 124.8% 110.8% 97.5% 0.55V 66 19.2% 69.2Hz 3125 0 2.05ms
39° 135.7% 124.8% 110.8% 109.2% 0.80V 65 18.8% 69.2Hz 3156 0 2.05ms
39° 135.7% 124.8% 110.8% 95.9% 0.18V 65 18.4% 62.9Hz 3125 0 2.05ms
39° 135.7% 124.8% 110.8% 95.9% 0.80V 65 18.4% 62.9Hz 3125 0 2.05ms
39° 135.7% 124.8% 110.8% 74.1% 0.51V 65 18.4% 62.9Hz 3125 0 2.05ms
39° 135.7% 124.8% 110.8% 93.6% 0.14V 65 18.4% 62.9Hz 3094 0 2.05ms
39° 135.7% 124.8% 110.8% 86.6% 0.74V 65 18.4% 62.9Hz 3125 0 2.05ms
39° 135.7% 124.8% 110.8% 91.3% 0.14V 65 18.4% 62.9Hz 3094 0 2.05ms
39° 135.7% 124.8% 110.8% 87.4% 0.76V 65 18.4% 62.9Hz 3094 0 2.05ms
39° 135.7% 124.8% 110.8% 81.1% 0.12V 65 18.4% 62.9Hz 3094 0 2.05ms
39° 135.7% 124.8% 110.8% 88.1% 0.72V 65 18.8% 62.9Hz 3094 0 2.05ms
39° 135.7% 124.8% 110.8% 97.5% 0.45V 66 19.2% 69.2Hz 3094 0 2.30ms
39° 135.7% 124.8% 110.8% 79.6% 0.53V 66 19.2% 69.2Hz 3094 0 2.30ms
38° 135.7% 124.8% 110.8% 86.6% 0.74V 66 19.2% 69.2Hz 3063 0 2.30ms
38° 135.7% 124.8% 110.8% 91.3% 0.27V 66 19.2% 69.2Hz 3094 0 2.30ms
38° 135.7% 124.8% 110.8% 84.2% 0.16V 66 19.2% 69.2Hz 3063 0 2.30ms
38° 135.7% 124.8% 110.8% 92.0% 0.78V 66 19.2% 69.2Hz 3063 0 2.30ms
39° 135.7% 124.8% 110.8% 101.4% 0.08V 67 19.6% 69.2Hz 3063 0 2.30ms
38° 135.7% 124.8% 110.8% 110.8% 0.80V 67 19.6% 69.2Hz 3063 0 2.30ms
38° 135.7% 124.8% 110.8% 103.7% 0.14V 67 19.6% 75.5Hz 3063 0 2.30ms
38° 135.7% 124.8% 110.8% 102.2% 0.70V 67 19.6% 69.2Hz 3063 0 2.30ms
38° 135.7% 124.8% 110.8% 106.1% 0.18V 67 19.6% 69.2Hz 3063 0 2.30ms
38° 135.7% 124.8% 110.8% 100.6% 0.68V 67 19.6% 69.2Hz 3063 0 2.30ms
38° 135.7% 124.8% 110.8% 110.0% 0.16V 67 19.6% 75.5Hz 3063 0 2.30ms
38° 135.7% 124.8% 110.8% 99.8% 0.59V 67 19.6% 75.5Hz 3031 0 2.30ms
38° 135.7% 124.8% 110.8% 97.5% 0.72V 67 19.6% 75.5Hz 3063 0 2.30ms
38° 135.7% 124.8% 110.8% 111.5% 0.68V 67 19.6% 75.5Hz 3063 0 2.30ms
38° 135.7% 124.8% 110.8% 103.0% 0.16V 67 19.6% 69.2Hz 3063 0 2.30ms
38° 135.7% 124.8% 110.8% 103.0% 0.74V 66 19.2% 69.2Hz 3031 0 2.30ms
38° 135.7% 124.8% 110.8% 107.6% 0.21V 66 19.2% 69.2Hz 3063 0 2.30ms
38° 135.7% 124.8% 110.8% 94.4% 0.64V 66 19.2% 69.2Hz 3031 0 2.30ms
38° 135.7% 124.8% 110.8% 110.0% 0.12V 66 19.2% 69.2Hz 3031 0 2.30ms
38° 135.7% 124.8% 110.8% 103.0% 0.72V 67 19.6% 69.2Hz 3063 0 2.30ms
38° 135.7% 124.8% 110.8% 106.1% 0.16V 67 19.6% 69.2Hz 3063 0 2.30ms
38° 135.7% 124.8% 110.8% 98.3% 0.53V 67 19.6% 75.5Hz 3063 0 2.30ms
38° 135.7% 124.8% 110.8% 109.2% 0.78V 67 20.4% 75.5Hz 3063 0 2.30ms
37° 135.7% 124.8% 110.8% 109.2% 0.06V 72 23.9% 100.6Hz 3094 0 3.33ms
36° 135.7% 124.8% 110.8% 114.7% 0.82V 74 25.1% 119.5Hz 3094 0 3.58ms
35° 135.7% 124.8% 110.8% 85.8% 0.74V 75 25.9% 132.1Hz 3156 0 3.58ms
34° 135.7% 124.8% 110.8% 92.8% 0.80V 75 26.3% 138.4Hz 3156 0 3.58ms
34° 135.7% 124.8% 110.8% 81.1% 0.16V 75 26.3% 138.4Hz 3188 0 3.84ms
34° 135.7% 124.8% 110.8% 74.9% 0.64V 75 26.3% 138.4Hz 3219 0 3.84ms
34° 135.7% 124.8% 110.8% 99.8% 0.35V 75 25.9% 138.4Hz 3250 0 3.84ms
34° 135.7% 124.8% 110.8% 98.3% 0.06V 79 30.6% 176.1Hz 3313 0 5.12ms
28° 135.7% 124.8% 110.8% 100.6% 0.82V 83 32.9% 220.2Hz 3375 0 5.38ms
27° 135.7% 124.8% 110.8% 79.6% 0.18V 84 33.7% 245.3Hz 3438 0 5.63ms
24° 135.7% 124.8% 110.8% 94.4% 0.70V 85 34.1% 276.8Hz 3531 0 6.14ms
21° 135.7% 124.8% 110.8% 92.0% 0.29V 84 33.7% 295.6Hz 3594 0 6.66ms
20° 135.7% 124.8% 110.8% 95.2% 0.33V 81 31.0% 239.0Hz 3688 0 5.63ms
28° 135.7% 124.8% 110.8% 136.5% 0.02V 80 29.4% 213.9Hz 3781 0 5.12ms
32° 135.7% 124.8% 110.8% 141.2% 0.53V 74 25.5% 132.1Hz 3813 0 3.33ms
38° 135.7% 124.8% 110.8% 166.9% 0.04V 73 24.3% 119.5Hz 3813 0 3.07ms
39° 135.7% 124.8% 110.8% 148.2% 0.78V 70 21.6% 94.4Hz 3844 0 2.30ms
41° 135.7% 124.8% 110.8% 117.0% 0.68V 67 18.8% 69.2Hz 3813 0 1.79ms
41° 135.7% 124.8% 110.8% 117.0% 0.88V 60 15.7% 81.8Hz 3875 0 2.05ms
41° 135.7% 124.8% 110.8% 86.6% 0.72V 52 12.2% 62.9Hz 3750 0 1.79ms
41° 135.7% 124.8% 110.8% 56.9% 0.47V 41 11.4% 62.9Hz 3719 0 1.79ms
40° 135.7% 124.8% 110.8% 81.9% 0.82V 63 22.7% 94.4Hz 3656 0 2.30ms
40° 135.7% 124.8% 110.8% 75.7% 0.12V 72 23.5% 106.9Hz 3719 0 2.82ms
39° 135.7% 124.8% 110.8% 97.5% 0.76V 74 25.5% 125.8Hz 3719 0 3.07ms
37° 135.7% 124.8% 110.8% 95.2% 0.78V 74 25.5% 132.1Hz 3719 0 3.07ms
38° 135.7% 124.8% 110.8% 77.2% 0.88V 58 15.3% 56.6Hz 3656 0 2.05ms
40° 135.7% 124.8% 110.8% 48.4% 0.80V 44 9.8% 62.9Hz 3688 0 1.79ms
40° 135.7% 124.8% 110.8% 52.3% 0.51V 36 9.8% 56.6Hz 3625 0 1.54ms
40° 135.7% 124.8% 110.8% 36.7% 0.47V 36 9.8% 56.6Hz 3594 0 0.00ms
27° 135.7% 124.8% 110.8% 99.8% 0.76V 36 9.8% 50.3Hz 3500 0 0.00ms
27° 135.7% 124.8% 110.8% 99.8% 0.00V 36 9.8% 44.0Hz 3469 0 0.00ms
27° 135.7% 124.8% 110.8% 99.8% 0.00V 36 9.8% 44.0Hz 3438 0 0.00ms
27° 135.7% 124.8% 110.8% 99.8% 0.00V 36 9.8% 44.0Hz 3375 0 0.00ms
27° 135.7% 124.8% 110.8% 99.8% 0.00V 36 9.8% 44.0Hz 3219 0 0.00ms
26° 135.7% 124.8% 110.8% 99.8% 0.00V 36 9.8% 44.0Hz 3031 0 0.00ms
26° 135.7% 124.8% 110.8% 99.8% 0.00V 36 9.8% 37.7Hz 2813 0 0.00ms
26° 135.7% 124.8% 110.8% 99.8% 0.00V 36 9.8% 37.7Hz 2594 0 0.00ms
25° 135.7% 124.8% 110.8% 99.8% 0.00V 36 9.8% 31.5Hz 2406 0 0.00ms
25° 135.7% 124.8% 110.8% 99.8% 0.00V 36 9.8% 31.5Hz 2188 0 0.00ms
24° 135.7% 124.8% 110.8% 99.8% 0.00V 36 9.8% 31.5Hz 2000 0 0.00ms
23° 135.7% 124.8% 110.8% 99.8% 0.00V 36 9.8% 31.5Hz 1844 0 0.00ms
18° 135.7% 124.8% 110.8% 99.8% 0.00V 36 9.8% 25.2Hz 1656 0 0.00ms
14° 135.7% 124.8% 110.8% 99.8% 0.00V 36 9.8% 25.2Hz 1500 0 0.00ms
11° 135.7% 124.8% 110.8% 99.8% 0.00V 36 9.8% 25.2Hz 1344 0 0.00ms
8° 135.7% 124.8% 110.8% 99.8% 0.00V 36 9.8% 25.2Hz 1188 0 2.05ms
16° 135.7% 124.8% 110.8% 99.8% 0.00V 36 9.8% 25.2Hz 1156 0 2.05ms
19° 135.7% 124.8% 110.8% 99.8% 0.02V 36 9.8% 25.2Hz 1125 0 2.05ms
18° 135.7% 124.8% 110.8% 99.8% 0.82V 36 9.8% 18.9Hz 1125 0 1.79ms
17° 135.7% 124.8% 110.8% 99.8% 0.70V 36 9.8% 18.9Hz 1094 0 1.79ms
18° 135.7% 124.8% 110.8% 99.8% 0.68V 36 9.8% 18.9Hz 1063 0 1.79ms
16° 135.7% 124.8% 110.8% 99.8% 0.76V 36 9.8% 18.9Hz 1063 0 1.79ms
14° 135.7% 124.8% 110.8% 99.8% 0.78V 36 9.8% 18.9Hz 1031 0 1.79ms
15° 135.7% 124.8% 110.8% 93.6% 0.78V 36 9.8% 18.9Hz 1000 0 1.79ms
15° 135.7% 124.8% 110.8% 89.7% 0.31V 36 9.8% 18.9Hz 969 0 1.79ms
14° 135.7% 124.8% 110.8% 95.9% 0.06V 36 9.8% 18.9Hz 969 0 1.79ms
12° 135.7% 124.8% 110.8% 99.8% 0.04V 27 9.8% 18.9Hz 938 0 1.79ms
12° 135.7% 124.8% 110.8% 106.1% 0.08V 27 9.8% 18.9Hz 938 0 1.79ms
12° 135.7% 124.8% 110.8% 110.8% 0.21V 27 9.8% 18.9Hz 938 0 1.79ms
12° 135.7% 124.8% 110.8% 107.6% 0.80V 21 9.8% 18.9Hz 906 0 1.79ms
12° 135.7% 124.8% 110.8% 103.0% 0.78V 21 9.8% 18.9Hz 875 0 1.79ms
12° 135.7% 124.8% 110.8% 97.5% 0.76V 21 9.8% 18.9Hz 844 0 1.79ms
14° 135.7% 124.8% 110.8% 92.0% 0.76V 21 9.8% 18.9Hz 813 0 1.79ms
13° 135.7% 124.8% 110.8% 87.4% 0.80V 21 9.8% 18.9Hz 813 0 1.79ms
12° 135.7% 124.8% 110.8% 82.7% 0.80V 21 9.8% 18.9Hz 813 0 1.79ms
11° 135.7% 124.8% 110.8% 78.0% 0.76V 21 9.8% 18.9Hz 813 0 1.79ms
10° 135.7% 124.8% 110.8% 73.3% 0.60V 21 9.8% 18.9Hz 781 0 1.79ms
10° 135.7% 124.8% 110.8% 74.1% 0.10V 22 9.8% 18.9Hz 750 0 1.79ms
10° 135.7% 124.8% 110.8% 76.4% 0.04V 22 9.8% 18.9Hz 750 0 1.79ms
8° 135.7% 124.8% 110.8% 78.0% 0.04V 22 9.8% 18.9Hz 750 0 1.79ms
The answer isn't that easy. I don't have an afc or maft, just an eprom tuned for all my modifications (see profile). This is an intermittent problem that has nothing to do with the tuning or the current state of my fuel trims, they fluctuate all the time anyway.
