what fuel pressure?
tcavenger99
109
May 24, 2008
mount pearl,
I have installed an ajustable fmu with amsn thanks to your guys help (thanks again). Now one more question, i have hooked a fuel pressure gauge up to the fuel rail and it reads 55 psi , when i tighten the screw on the fmu in increases .How much pressure should i have for boost ? plus i am getting a boog out feeling sometimes when i floor it from a stop when boost hits, is this due to low fuel pressure .
specs---warlbro 225 fuel pump
high flow injectors
missing link
fmu
What is your fuel pressure while in vacuum? With larger than stock injectors, you will want lower than stock fuel pressure to keep from running so rich.
Consider investing in a wideband.
at idle my fuel presure sit right between 40 and 45 psi. but my gauge isnt on the fuel rail, its mounted on my fuel presure regulator so i dont know if there would be a difference there. so are you asking what your fuel preasure should be when you hit boost?
ok at first my fuel pressure was at 45 them i raised it to 55 by tighting the fmu screw. this was all done at idel
