What fuel line to feed nitrous???
4g63telantra
454
Dec 10, 2004
Toronto,
Quick Question here:
When hooking up a wet fogger nitrous system, where would I hook up the fuel line to the kit too?
Would it be from the stock fuel lines and buy a Y-block?
You can put a tee in the stock fuel feed line.
Which kit do you have? There's a direct port kit from NOS (The Pro Race Fogger) that requires a dedicated fuel line. As long as you don't have that, you should be fine tee-ing the stock feed.
You could get the b&m fuel pressure gauge kit that lets you put the guage on top of the fuel filter but instead of putting the gauge in the fitting use it to feed the feul line. Would be a clean way of doing it
