2G What does this ground
Dirtbike29
134
16
Mar 10, 2024
Surrey, BC, Canada
I’m having some issues with getting my high beams and fog lights to work is this the ground terminal for high beams and so on passenger wheel well usa car
That is a body ground multi-connection "block". There are multiple versions of them on the vehicle. For exact locations of each ground location reference the Electrical manual located on the site.
Well I cleaned it in vinegar tested it with a light probe all is good.
But my fog light switch isn’t sending power out of the switch it gets power in and ground in the switch is good.
The fog light switch puts a ground (if the dimmer passing switch is in LO position) on the fog light relay coil to activate it. The headlight relay must also be on and the 15A fuse (#6) must be good all to apply power to the fog lights (other side of fog lights goes to ground).
I have no blown relays my dimmer knob works fuse is brand new so I’m replacing the turn signal stock and the fog light switch see if it works if not I’m just wiring them to my head lights
Do you know what might be causing them not to work I got a new switch
