What do these compression #'s mean?
Megags
155
Oct 21, 2003
My car has been burning oil for a while, I'm tired of it so I decided to test the rings to see if I could get away with a freshening of the head. I only see it smoke when it has been idling for a few minutes (3-5).
I need some advice on if the rings are okay. Here's the #'s
cyl1 195 wet>235 (used capful of oil)
cyl2 200 wet>230
cyl3 200 wet>230
cyl4 200 wet>235
All vacuum readings indicate a healthy motor. Please tell me what you think I should do. I'm tired of putting in oil. Nt compression is supposed to be 192psi and the service limit is 145psi. I didn't know if I even needed a wet test, but did it anyhow.
Thanks, just wasnt sure since it had higher comp than its supposed to have. lots of miles 176k.
Quasimondo said:
Most likely the problems are the valve seals.
Or, it could be the rings. Perform a leakdown test as recommended to get a grasp on where the oil consumption is coming from.
Let us know what you find,
Andy
  • Wanted 95 eprom
    Looking for 95 eorom
    • GhostTypeP0300
    • klipschaudio
    2g pass front rocker corner
    • dsmmario
