what do i need to use a safc2
rayrayx11
165
Aug 8, 2008
riverside, Rhode Island
im ok with cars but its the tuning im having trouble with. i have a 95 gst with port and polished head, 3 inch no cat exhaust, front mount, intake, 255 walbro, afpr, and boost gauge. i have found a safc2 for $150. thought it was a good deal but what would i need to be able to use this? alot of people use loggers, maft, and others. but would i need all that or could i get away without using just the safc2.
help please
def get a logger for any type of tuning. i would also recomend getting bigger injectors, 550's work well, you dont wanna max out your stock injectors.check pocketlogger out for a logger system. your stock maf would work fine also.
i read up on a form that all 95s have OBDII also. so i can use any obdII logger basically? my friend owns a shop and would let me use his if i needed. will i need a a/f gauge if i use a logger? and yea that was going to be my next step. 550s. i have a 14b and a 16g and light weight flywheel laying around. thats all going in too.
i would get at least a logger if not a wideband also. you can use the blue wire from the afc to tap into your o2 sensor and view the voltage but its kinda a crappy way to tune
