What connector is this? (pic)
clipseclipse
Mar 17, 2008
Sacramento, California
I believe this is unrelated to the problem I have posted in another thread which is why I'm making a new thread. Circled yellow is a connector coming from the passenger side area near the bumper, coming from a series of wires that connect to the turn signal light. It is burnt which is why it looks odd, but there are three wires connecting to it. Please help me identify it! I have a 95 rs so I believe I don't have an evap purge solenoid (please confirm this). Thanks.
Also, is my camshaft position sensor supposed to connect to the valve cover with a solid metal cylinder as circled in yellow below...blue tape is from previous owner.
Ahh, i see. I do not have an overflow tank in my car, so I it appears that the previous owner removed it. I have not lost any coolant from the regular resovoir though. Does the overflow tank fill up with regular use?
It appears that the cylinder in the pic 2 is grounding some sensor the the block/valve cover. It looked as if it were coming from the CPS area.
The overflow tank should never fill up completely. When the coolant gets hot, like when you turn off the motor after a long run on a hot day, it catches the overflow that may come out. Than when the motor cools it sucks it back into the radiator. The tank has two level marks on it one for when the car is hot and one when the car is cool.
You ought to have one just in case, it saves a mess in the engine compartment.
BK85
Slow; pic 2 is his CPS, although it's not exactly what he circled his CPS is right below it.
Edit: It's actually like half circled. I'm not to sure what it is that you circled though, OP.
I know his CPS is in pic two but he said ( , is my camshaft position sensor supposed to connect to the valve cover with a solid metal cylinder as circled in yellow below...)
That thing ( i think ) is supposed to help, with like feedback thou the radio.. But don't hold me to this...LOL
Ok, looks like I don't have the overflow bottle with the sensor attached, which is why I have my leftover connector. Ebay has one for sale for $100, which seems rediculous. Any recommendations of where to buy a replacement? Thanks for your replies guys, I appreciate it
  • Wanted 6 bolt NT water pipe
    • chrisman287
