What can i use instead of the stock 1g bov hose?
It will not fit if you have a 2g maf, I thought I was gonna be smart and buy the FP intake and prove them wrong. But on our 1g's there's really not enough space at all I wasn't even able to put a hose since the intake was almost hitting the 1g bov.
damn that sucks the fp one looks sweet i guess the polished 3" it is but should the extreme psi one connect without me having to buy a longer hose for the bov?
what kind of hose is that? and what size would i need for the stock 1g bov?
its a flex hose... i bought it from autozone... it has a spring inside so it doesnt bend alot when you twist it yet it pretty flexible...! just ask them for a hose with the spring inside and then measure the bov and the hose to make sure you get the right one... if its too long dont worrie you can always cut it as long as you want...! mine was too long so i had to trim a bit of it since my bov is facint the battery...!! hope this helps
yea i found the flex hose your talking about it doesnt fit snug on there but i bought clamps so it dont go nowhere did u use clamps for your flex hose also? i was thinkin the spring inside might block the air going threw it though?
well i bought the flex hose and put it on went for a spin and my bov flutters it doesnt make the wooosh sound anymore so im thinkin that spring inside is making the air spin in a loop as it exits? so i dunno what can i use now?
