What Can Cause 0 Compression
Status
Not open for further replies.
me612
1,423
5
Aug 8, 2002
Minneapolis, Minnesota
OK well first I'll give a little info on the car. 1991 Talon AWD, 110k miles. Mods are 50trim, stock longblock, typical supporting mods.
Yesterday I received my 3g lifters in the mail, so I put them in. I also changed the timing belt when I did this. I've done a dozen timing belt jobs before, so I'm 99.9% sure I did it right (I say 99.9 because obvoiusly something is wrong here so maybe somewhere somehow I did something wrong). I compressed the lifters before installing them also. Now basically I get this all together, and I pull the MPI fuse, let it rev for a little to get oil pumped through everything. Put it back in, go to start it, and nope. If I floored the pedal, it would start but wouldn't stay running. I decide to do a compression test (I was 150 across the board a month ago) now I'm at 150-0-0-150. I was told a leak down test won't work with absolutely 0 compression. You have to have atleast a little. I don't know, I decided to go back and check my timing belt again. It is still lined up perfectly. I figured maybe something happened somehow and I bent a valve. I took the head off, and everything looks to be fine. No valves "look" bent, the pistons look great (you can tell I just did the MCCC Cleaning!). Headgasket looked fine, I'm really confused. I'm bringing the head in to get pressure tested since it's out, but I'm wondering what else this could have been. What all can cause absolutely 0 comression? Not even 50psi of pressure, just flat zero. What could I have overlooked here?
Well the shop called me today and said that they noticed quite a few valves that were leaking. So I'm guessing it's safe to assume that is why I was seeing 0 compression in the 2 cylinders. I'm still not totally sure what happened, but I'm thinking maybe I didn't bleed some of those lifters as much as I should have. I know the timing was right, so I don't know.
Im thinking since the head is out, that I'll just go ahead and get it a nice refreshing. Probably just some new stock sized valves, stiffer springs since I have cams waiting to be installed, and that's probably it. I think that's plenty good for my 400hp goal.
k, next time you do this prceedure..take ## head flip it upside down.. and turn your cams so your valves are closed, and poor gas on the top of the valves and see if they leak that is the fastest and easyest way to see if anything is leaking...
Got the head back, 7 bent valves: cyl 2 = 2 exh, cyl3 = all 4, cyl 4 = 1 int. So with that being said, the head is being sent off to FFWD on Friday.
Status
