What cable is this? car wont start with it off
DSMnOOb00
903
4
Apr 29, 2006
FRESNO, California
I was in the middle of wiring up my new boost gauge (old one got stolen :cry: )
I decided to tap into my stereos power when I noticed a plug that had a wire looped back into itself.
I had never seen these cables before since it was buried in the mess of wires
So I unplugged the LOOP wire and everything seemed fine, but then the car wouldn't start! it wouldnt even turn over.
I placed that wire back and car fired right up, now I'm clueless on what the heck this wire was for?
<img src="http://i102.photobucket.com/albums/m82/raullags/photo-3.jpg" border="0" alt="Photobucket"></a>
<img src="http://i102.photobucket.com/albums/m82/raullags/photo2-3.jpg" border="0" alt="Photobucket"></a>
It goes to a relay either the fuel pump relay or another one mfi there should be two in back behind the radio
It looks like a harness connector for either the MFI relay, Fuel Pump relay or the Starter relay.
The presence/absence of the others along with the car's behavior might tell you which one.
http://www.dsmtuners.com/forums/newbie-forum/276071-mfi-fuel-pump-relay.html
What does the car do when you turn the key?
Does the engine turn over? -No, then it's the starter relay.
Does the fuel pump kick on? -No, then it's the fuel pump relay.
the car never turned over, nothing happened.
so if its a starter relay, why isnt it plugged in? I wounder what the owner before me was doing, maybe a kill switch? :confused:
Ok, I'll see if I can get around to pulling the console out of my 99 GSX today to see if I have that same connector.
perfect, that would be awesome! try to see where is goes, yours might be plugged in. take a picture if you can
btw you have the perfect eclipse, Spyder AWD! :rocks: I had to pick between a GS spyder or a GSX :cry: I owned both until my buddy bought my spyder and then crashed it
Someone probably had a relay go bad and bypassed it.
Btw, I do have a 97 awd spyder, but I was actually gonna check my 99 gsx coupe since the spyder doesn't have an interior atm.
  • Wanted 6 bolt NT water pipe
    • chrisman287
