Mitsu725
- 211
- 0
- Mar 22, 2004
DAVIE,
Florida
its not a vibration its more like a shake back and forth, mostly from 60-80 or in low mph when i get on it, its weird, i thought it might have been the engine for some odd reason i dont know but its not, i have eurathene motor mounts so im used to the rough ride, but i replaced the lower control arm today-(curved) but its still acting up, now my outer tie rod is also bad because we did the shake down test, up and down is ball joint and left to right is the tie rods and i had play both ways, well the lower control arm ball joint was extremely bad, but even after replacing the problem is still there, could this all be from the outer tie rod, or maybe some bushing or wheel bearing?? or maybe even suspension.
Shaking would come in and out intermittently, when wheels come in and out of balance (while on the highway at higher speeds). New tires solved the problem.
