weird idling
screwdgie
254
4
Apr 6, 2003
Barrington, Illinois
When I am crusing to a stop in neutral, the rpms will go up to 1500 then drop to 1000 and back and forth until i come to a complete stop. It only does it when rolling to a stop. Anyone know what this might be?
Not neccessarily at the TB. I've had the same problem, and it turned out to be a crack in my downpipe, the leak can be anywhere from that point up, could also just be a matter of getting it tuned, but most likely a leak.
I've never heard of a leak "after" the combustion cycle causing idle probs before. Partly because the problem is caused by the air metering being off due to the leak before combustion causing a rich condition at idle.
But true, the leak could technically be anywhere in the intake tract. Test for leaks.
An "exhaust" leak in front of the first o2 sensor can also create an idle problem, not only in the intake.
I think i have fixed the problem. I tried adjusting my BISSS screw. The rubber cover that was supposed to be over it wasn't. I tightened it until my idle went down from like 1200 to 750-800. I test drove it and it idled better than ever at a stop and rolling.
Just to see what would happened, i loosened the screw all the way out. The car idle back and forth from 1300-1500. It sounded really nice, like it was cammed. I test drove it like that and ran fine too.
