Weird headlight question
matt j
89
Oct 1, 2003
sioux falls, South Dakota
Alright, Here is the issue that i am having. A while back a wire got arced on the a/c fan relay (check vfaq for the post points) 1 and 3 to hardwire a switch in to manually turn my cooling fans on. Well now every now and then the headlights will just sit and flash on and off, just like if the factory alarm was going off, but there is no horn sound. The fuse and relay for the factory alarm system has been pulled and it still does it. I would like to figure out what the problem is so that way it can be fixed and my headlights stop flashing.
Also, another question that i have, my car will not start. It was running last night to drive it home and i went to jump in it this morning to defrost the windshield (stupid cold weather) and the car would just crank. I tried to also push start it with no luck. The compression is good, there is spark, there is fuel in the rail, and the CAS and timing are dead on nuts. So what other issues could it be? I also just installed an SAFC1 in the car, but i have set up on 4cyl with progressive throttle and on karmen vortex. So if anybody has any answers for these questions i would greatly appreciate it.
The car is a 1990 eagle talon tsi awd
