WBO2 cycining?
How large of a cycle are you talking about? At idle it's normal for the WB reading to fluctuate a little bit. At idle my WB will fluctuate from about 14.8 to 15.4. But the WB should not be cycling with a large variance like the NB signal.
Is this cycling that you are talking about showing up on the gauge or as a logged voltage reading?
Yes the WBO2 will fluctuate when in closed loop(idle, cruising), but when the car goes into open loop(flooring it or getting on the throttle) the AFR should read fairly steady.
  • For sale 2g VRSF 2g FMIC.
    Bar and plate. 28x10x3.75. 2.5 inlet and outlet. 36.5 on center inlet and outlet Pretty...
  • For sale 2g Eclipse/Talon Passenger Side Fenders
    95-99 Eclipse/Talon Passenger Side Fenders
    • Sdcryan1
  • Wanted Driver Side Front Side Skirt End for 97-99
    Looking for the driver side skirt end molding. Bonus if it has the mud/rock guard.
    • ProjectDSM
  • For sale 1997 Eagle talon esi
    runs and drives located in Oklahoma City
    • Nii
  • For sale 2 bare 7 bolt motors
    bare 7 bolt bottom ends
    • Nii
