wastgate install??
96eclipsex
93
Sep 29, 2005
Rutledge, Tennessee
can anyone tell me if my wastegate is hooked up right
for some reason i cant run under 10 psi
Run a vac line from a boost source directly to your wastegate and see if that changes anything. If it doesn't then the spring in your wastegate is a 10psi spring and you will have to change out to a softer spring to lower boost. If it does go lower then you need to adjust your mbc or take it out completely if you can't adjust it anymore.
m1nd64m3 said:
Isnt the top port on the wastegate only used for electronic boost controllers? Mine goes from vac line teed from the bov to the mbc then from the boost controller to the side port of the wastegate.
Totally missed that good eye! I was too busy copying the pic and zomming in trying to read what was written on the pic.
Agreed. Leave the top open and run the side to the mani or any othe boost soucre. I made my own boost source in my ic pipe. Works great for the wastegate.
