wastegate
No I have not connected the two vacume lines together eliminating the MBC. I just turned the boost controller all the way down and all it really did was slow the boost creep. should I connect the two lines. I have another Evo III turbo that I just took the inlet off and will port or send it out.
I want it to be at 14 and is rising to over 20psi. I have two Evo II turbos and put my second ones wastegate on it and it is doing the same thing.but it was bent to begin with so i wasn't expecting it to work. If I went with external Id need a new manifold and waste gate. I don't have the money How can I fix boost creep without buying these things. Do you think its the turbo.
well ther is such thing as external tial 38mm o2 housings. you use your existing mani and you completely take the flapper out of the exhaust housing of the turbo and leave it open. im going to run this same setup with my 20g.
heres the o2 i have waiting to be usedBlank
i have the one that recircs back in.
now the only bad thing is you have to buy the wastegate and the o2 (which is what you don't want to do) but i just wanted to put this out ther and recommend it. do you need it??? NO all you need is a lil friendly porting.
