wastegate?
Here is what robert @ forced performance said about that on his race manifold announcement:
Sorry, no single runner wastegate flanges on our manifold. People still do that?
What happens if you need to WG more than 25% of the flow out of the motor to hold motor down to a certain boost? Does that mean that some of the flow from the 3 other runners has to travel backwards down the #1 runner in order to get out of the WG? That is rhetorical of course, do not attempt to answer, we all know how poor of a solution that truly is.
This manifold is designed to support the FP30 turbos, and they all have integral WG ports made into the turbine housing so that WG flow can be drawn equally from all runners. Of course most turbos are made this way with internal gates, and any of those will work rather well with this manifold.
well, back to the lab.
Here is the thread on that:
http://www.dsmtuners.com/forums/showthread.php?t=252160
  • Wanted 6 bolt NT water pipe
    • chrisman287
