Synapse wastegate?
xxNocturnalxx
698
12
Nov 5, 2011
Tacomptan, Washington
Anyone running a Synapse wastegate? How do you have the ports hooked up and how much boost are you running? Anyone have any luck getting a MBC to work on it?
Currently having trouble getting my boost dialed in. I have read through the manual and pretty much have it memorized. I also have been on there forums and they are not much help so I'm looking for specific set-ups on the 4g63t motor. My current set-up is the 50mm with the 40mm seat and 60lb. spring, preload turned all the way in. 10 psi. on port D. trying to reach 18-20psi.
Well, I think I got it figured out. I'm running port AB and C.. with the MBC tied into port A&B and I can get 9psi. on the low end and 20+psi. on the high, wow that only took weeks and this wastegate leaks out of the valve stem and ports under boost leak tests, I don't recommend them what so ever.
