Waste gate leak
grdsm
51
Oct 12, 2007
GRAND RAPIDS, Michigan
Before My engine went out I had a leak at my external waste gate, I was told that I can make a gasket out of stainless steel. I made a gasket and it ran good for about 10 mile and it went back to the samething. I don't know what to do because of it it is a very tight fit because the of the power steering pump, dump pipe and the exhaust pipe. I was thinking there is a flange the sticks out of the waste gate into the header right inbetween the gasket I made, I looks like that is not sealing right. CAN I grind down this flange so that when I bolt it up they fit closer together? help please
Don't grind that flange. You're not accurate enough with a grinder, you'll make it worse. You know, they sell gaskets that fit that specific application. Also, I'd have made it out of a thick copper material, not SS. Thin SS seems to like to warp a lot whenever I've worked with it.
Another (ghetto) solution is axle grease. I use it between my turbine and manifold mating surfaces. If they are flat enough, then the grease will burn and turn into carbon, pretty much the ultimate high temp seal :D
Another thing, is it leaking past the valve, or is it leaking out into the atmosphere? If it's leaking past the valve, that's something completely different.
